N54 oil level sensor help
Old 03-29-2019, 10:29 AM
Chasebryant88's Avatar
My Ride: 2008 535i
Engine: N54
Default N54 oil level sensor help
Hello everyone I just purchased a 2008 535i that needed some work to fix up for a daily driver long story short one turbo shaft was broke pouring oil so it was reading low oil level I replaced the turbos and changed oil filter and replaced oil with 7 us quarts 5w30 took it for a test drive runs great no cel but when I tried to reset the oil life I couldn't so I checked the oil level on idrive and it reads min and says oil service required so I decided faulty sensor and replaced the sensor and added 7qts fresh oil and check it still min so I drive 20 miles to maybe let it reset let it sit over night to cool check it in the morning still minimum plug looks good wires look good I've searched Google motor logic forums and everyone just says replace sensor but it's the second new sensor with same results and now I'm lost not sure what to do from here any ideas would be greatly appreciated
Old 03-30-2019, 11:19 AM
audiophool's Avatar
My Ride: 535xi
Try adding 1/2 quart and see if it moves up from minimum.
Old 03-30-2019, 12:27 PM
My Ride: 2008 535i
Engine: N54
Thanks for the reply I tried adding oil with both replacement sensors and it never changed from min. Starting to wonder if the aftermarket sensors are calibrated differently or just not compatible if I can't figure anything else out by Friday I will break down and order an OEM sensor to try
Slammin
05-21-2011 09:20 PM
Forbidden8701
04-12-2010 03:53 AM
chosenone357
08-06-2009 05:10 AM
woody
02-27-2007 09:13 AM
2DOR
01-12-2005 01:57 AM
Quick Reply: N54 oil level sensor help
