My instrument cluster is not working after jump started my 2004 bmw 545i
My Ride: 2004 bmw 545i
Try disconnecting the negative battery terminal for 1-1.5 hours. This, with any luck, will reset all of the modules, so when you reconnect the negative terminal, all modules will reboot and all will be good.
i did for 30 minutes didnt work should i try again and wait 2 hours
My Ride: 07 550i Sports Package
If that doesn't work try disconnecting the instrument cluster for about 30 secs and then plug it in. It is not hard to remove just a few screws. Disconnect it only after you have disconnected the battery.
My Ride: e60 520d lci
Model Year: 2010
have you plugged it in to a diagnostics machine/laptop and check all fuses. how was it jump started? and have you checked your battery health
Model Year: 2010
djcentrino
06-24-2012 08:43 AM
miguex
10-21-2009 08:51 AM
