My instrument cluster is not working after jump started my 2004 bmw 545i
Try disconnecting the negative battery terminal for 1-1.5 hours. This, with any luck, will reset all of the modules, so when you reconnect the negative terminal, all modules will reboot and all will be good.
Originally Posted by jtbgonesailing
(Post 1594211)
Originally Posted by muzamel7
(Post 1594213)
i did for 30 minutes didn't work should i try again and wait 2 hours
Originally Posted by Gee_115
(Post 1594214)
If that doesn't work try disconnecting the instrument cluster for about 30 secs and then plug it in. It is not hard to remove just a few screws. Disconnect it only after you have disconnected the battery.
have you plugged it in to a diagnostics machine/laptop and check all fuses. how was it jump started? and have you checked your battery health
Originally Posted by youngbmw
(Post 1594264)
(Post 1594214)
(Post 1594211)
(Post 1594426)
Hello i got a new cluster plugged it in and it wgorked and it now says passenger restraint malfunction and my idrive controller when i push down on it doesn't work
(Post 1594427)
the restraint malfunction can usually be reset with a diagnostic machine
all this from jump starting? did you clamp the positive lead directly onto your fuse box?
how does this happen... |
