is my idrive dead pleas help
Old Jul 18, 2013 | 06:58 PM
noberryafterdingl's Avatar
My Ride: stock e60
Default is my idrive dead pleas help
i went to formation this mornin at 0430 plugged my phone into aux and was fine, had music, legal disclaimer etc..i then got back int the vehicle at 1200 it was 96 degrees out windows rolled up to my surprise the idrive did not come on.. insted u could see the backlight with a black black screen with very faint white lines..... still got all the chimes parking sensor still worked, no radio, no aux-in, no bluetooth, checked fuses in the trunk or boot radio amp, and video fuses were fine need to know if i can diagnose with inpa.... i can do simple coding with instructions
can someone tell me what are my options with replacement and coding/inpa
Old Jul 18, 2013 | 10:34 PM
H F's Avatar
H F
My Ride: 2005 545
check out this site BMW retrofits, coding and software updates - BimmerTech
Old Jul 19, 2013 | 04:23 AM
My Ride: stock e60
[QUOTE=H F;1513378]check out this site BMW retrofits, coding and software updates - BimmerTech[/QU
ive been looing at the combox but is that a plug n play or stand alone unit with out using the idrive computer
Old Jul 19, 2013 | 05:27 PM
Gee_115's Avatar
My Ride: 07 550i Sports Package
What equipment do you have? If you have a MOST coding equipment (OPS, etc), you could try just recoding the entire CCC. I would try that route before spending money.
Old Jul 20, 2013 | 09:16 AM
H F's Avatar
H F
My Ride: 2005 545
[QUOTE=noberryafterdingl;1513394]
I don't really know bout the combo box .but if u purchase a new unit it should b plug and play and controlled thru the idrive knob. I like bimmer tech stuff cause its an Oem upgrade. I myself am probably goen that route I have an 05 idrive system and want a newer looking graphics and system.
I think Gee_115 is giving u good advice to recode first ,,makes dollars and sense. If it don't fix the problem then go for the upgrade.
Old Jul 21, 2013 | 06:25 PM
dbond's Avatar
You are likely S.O.L. CCCs are known to die from heat - breakdown of soldering within microchips. Your options are to get a used CCC or upgrade to CIC. The later will open a path to Combox.
BuddyB
Aug 17, 2017 12:48 AM
PakiBeamer
Dec 9, 2016 04:40 AM
Henry Peters
Sep 25, 2015 10:15 AM
EuropeanArtz
Sep 23, 2015 08:21 PM
Claudiupromotion
Sep 17, 2015 08:02 PM
