Multiple features not working
Old Jul 27, 2011 | 05:56 AM
ryan60isu's Avatar
I have a 2007 550i and the following things are not currently working. I checked every single fuse in the glove compartment and all potential fuses in the trunk (according to the fuse chart). Is it possible that when locating the fiber optic cable in my glove compartment I pulled out (dislodged) a connection in the back of the fuse box?
  • Wipers
  • Interior lamps (ambient, red, lighting still works correctly)
  • Cruise control
  • Exterior puddle lamps
  • Trunk release (interior and on fob)
  • Glove compartment lamp
Any and all suggestions would be greatly appreciated!
Thanks!
Old Jul 27, 2011 | 06:15 AM
MisterMike's Avatar
Wish I could somehow direct you to the right location, but that's definitely what it sounds like to me. I'd guess that you've disconnected some part of the wiring harness somewhere.
Old Jul 27, 2011 | 06:20 AM
John@Motorcepts's Avatar
Banned
My Ride: A Car
Check if the following is in the same section:
  • Wipers
  • Cruise control
If not, it could simply be a battery problem. You should visit a local shop with access to the GT1
Old Jul 27, 2011 | 06:23 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
I suppose you put the connection back afterwards...
Maybe you didn't plug it all the way.
Did the problems start after this or later?
- Antti -
Old Jul 27, 2011 | 06:29 AM
ryan60isu's Avatar
I'm going to double check my fuse map and see if they are all in the same region, as that's a simple way to try and pinpoint the issue.
The optical connector is back in place as the radio works.
Old Jul 27, 2011 | 06:31 AM
ryan60isu's Avatar
Sorry for my ignorance, but what is a GT1 and what all will a scan show? Maybe that's the easiest route to take.
Thanks again for all the help!
Old Jul 27, 2011 | 06:41 AM
545felix's Avatar
My Ride: 05 545/6
there's a lot of modules behind the glove box, it's unlikely but possible you disconnected one of the other wire harnesses back there. check all connections back there, not just the fuse box. I'd recommend disconnecting the negative cable on the battery first just for the sake of your electronics.
Old Jul 28, 2011 | 05:02 PM
ryan60isu's Avatar
Good news. This afternoon I disconnected the negative terminal, removed the fuse panel, and what do I see, a set of wires unplugged.
Plugged it in, put everything back together, and Bertilda the Bimmer is all good again
I'm still a little perplexed as to how it became unplugged. I wasn't yanking any wires or being forceful, but who knows, perhaps it was lose and I just give it that final nudge.
Thanks again!
norsecarnut
Jun 27, 2015 05:47 PM
i6YouNot
May 19, 2015 02:40 PM
fmusbmw
Bluetooth & Cell Phone Forum
May 14, 2004 11:41 PM
buddy
Mar 13, 2004 12:27 AM
