Multiple Codes thrown at once. Places itself in park.
My Ride: 535i
2008 535i E60 114,000 Miles
Sport Package
Changed the battery about a year ago
Last night I start the car and it had a low battery and the clock was reset. I thought maybe it was the Bluetooth adapter connected to it that was not letting the car go to sleep. I thought I will drive it to work and it will charge the battery back to full. I get back into go home and the clock was at the correct time. I thought "ok cool, it is happy".
On the way home from work I had the car washed. Drove about 10 miles and stopped at a gas station to grab a drink. I start the car up and reverse, I put it in drive and drive 3 feet and BAM, the car puts itself in park, I loose power steering. The dash lights up like a christmas tree with transmission, antilock brake, anti roll, running hot, ect. I shut the car off. At this point I am parked sideways at the gas station so I start it back up and reverse it to get it out of the way of traffic and after about 2 feet it throws itself into park again, rinse and repeat. I cleared codes and it does the same thing
I had the car towed to my house.
I was able to gently pull it onto and back off the tow truck. As soon as I gave it adequate throttle it goes nuts again.
I was thinking it was a battery or alternator thing so I check the voltage of the car and she reads 12.6. I start it up and it jumps to a little over 13 volts. I noticed when I let the car idle is runs without throwing a bunch of codes. When I rev to around 3 grand it acts crazy again.
I have a trickle charge on it now.
I ran codes and pulled 23 faults using the Carly for BMW app.
See below for the codes thrown.
(They all seem to be related to voltage)
Motor Control:
Engine / Motor
steering wheel angle
Code: 00CDA1
Message (control EAF)
Code: 00CD95
Power-management power failure
Code: 002DEB
electric coolant pump, shut down
Code: 002E82
:Filler Cap Sensor / Valvetronic servomotor: Overload / Tank sensor, right: Signal
Code: 002DE5
:Tank level sensor, left: signal / Filler Cap Sensor / Valvetronic servomotor control
phase W: Line break
Code: 002DE4
Generator, communication: Bus error
Code: 002E98
ABS / DSC / Brake:
Active Roll Stabilization / Rollstabilisierung
KL30 ECU ARS
Code: 005D61
Dynamische Stabilitaets Kontrolle / DSC
Uz supply voltage
Code: 005DD0
CAN error message
Code: 00D359
:CAN fault / CAN message
Code: 00D36D
:unknown failure / CAN fault
Code: 00D36E
Transmission Control:
Transmission / Getriebe GS 19
sorry, unknown fault
Code: 00CF2E
Position Info CAN
Code: 0051AA
unknown failure
Code: 0050DC
Battery voltage
Code: 005014
Transmission / Getriebesteuerung
ECU not present/no response from ECU
Gear switch / Gangschalter
Code: 00E09A
Code: 00A83C
Instrument cluster:
Instrument cluster / Kombiinstrument
supply voltage failure
Code: 00931D
Gateway
Servotronik failure
Code: 0093BD
Steering column switch / Lenkstockschalter
LRE monitoring of voltage above the upper limit
Code: 00951B
I am thinking maybe alt or battery but I really dont know. Has anyone seen anything like this happen?
Sport Package
Motor Control:
Engine / Motor
Code: 00CDA1
Code: 00CD95
Code: 002DEB
Code: 002E82
Code: 002DE5
phase W: Line break
Code: 002DE4
Code: 002E98
ABS / DSC / Brake:
KL30 ECU ARS
Code: 005D61
Uz supply voltage
Code: 005DD0
CAN error message
Code: 00D359
Code: 00D36D
Code: 00D36E
Code: 00CF2E
Position Info CAN
Code: 0051AA
unknown failure
Code: 0050DC
Battery voltage
Code: 005014
Code: 00E09A
Code: 00A83C
Instrument cluster:
Code: 00931D
Gateway
Servotronik failure
Code: 0093BD
Code: 00951B
Hey what's up. Yeah it sounds like the battery. You should check to see the age of the battery since most of them will last for about 5 years. Also that time is shorter every time the battery is run down, IIRC you lose a 1/2 volt each time. Try to charge your battery but if it happens again then time to replace the battery. Also I'm sure you know short trips kill the battery since you need to be driving it for at least 30-60 mins med to high speeds to really charge the battery.
My Ride: 535i
Changed the battery and still no dice. I am thinking Voltage Regulator. I will check the brushes when I get home from work.
