MP3 playback on Professional Stereo
Old 09-02-2004, 05:08 AM
JDN
JDN's Avatar
But, OTOH, DD, with 150 to 200 selections on a CD, who needs a changer? Oh, you must lose the dash slot when you opt for the changer?
Old 09-02-2004, 05:10 AM
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
Good point!
Old 09-02-2004, 05:54 AM
Doctor Diesel's Avatar
Why do you lose the dash slot, I've a changer and a dash slot and am led to believe when the software update comes, the dash slot will play mp3's and cd audio, the changer just cd audio (and the other dash slot plays nav discs and dvd's)
Am I missing something??
DD
Old 09-02-2004, 06:44 AM
JDN
JDN's Avatar
That was why I questioned your "bummer" comment. Who needs a changer to handle MP3 with 200 selections per CD? My bladder won't last that long.
Old 09-02-2004, 06:56 AM
530E60NL's Avatar
I always question the MP3 soundquality.. I even hear a difference between the hybrid SACD's I play in my car and normal CD's!
JDN, I think with MP3 your coffeemugs will need an upgrade to a larger size
Old 09-02-2004, 08:40 AM
don't forget the travel potty!
seriously, mp3 quality is noticeably poorer than original cd quality even in the car...it would be nice to have both, also the changer is a cheap option in the uk.
dd
Old 09-02-2004, 09:40 AM
JDN
JDN's Avatar
Quality issue 'specially pertinent if most of the selections are Morpheus downloads as mine are. OTOH, a true audiophile would not consider a moving vehicle the ideal sound chamber.
Old 09-02-2004, 11:50 AM
Russ1974's Avatar
I would have to disagree. I have a very expensive hi-fi set up at home, and play both MP3's (from a hard-drive based system) and CD's and cannot audibly tell any difference between them. It's a good system and I have good hearing!
In our other car, an Audi, I have a Bose stereo with a nav system which plays MP3's from SD/MMC cards, and CD's from a changer. Again there is no difference in quality between them.
Now I know people can have long arguments about the coding, compression etc - but when it comes down to it if it _sounds_ good then who cares about the technical specifications. I am yet to find somebody who can tell whether they are listening to an MP3 or CD of the same track when fed through the same system from a _good quality_ MP3 source or CD player (ie, don't compare a ?2000 CD player to a ?300 PC outputting through a ?5 sound card...!)
Old 09-02-2004, 08:09 PM
skipper's Avatar
Originally Posted by JDN' date='Sep 1 2004, 05:17 PM
I can now get about 20-22 pieces in cda format converted from mp3 on one CD. Looking forward to getting 700 MB of mp3. That should be about 200 if I trim out some of the Mozart.
Burn them on a dvd and play them in the NAV dvd player. You can get hundreds on there. That is why you have the option to select DVD from the entertainment area.
Old 09-02-2004, 09:59 PM
JDN
JDN's Avatar
I guess that's an option, but I use NAV a lot plus I don't have a DVD burner. I didn't realize NAV had a DVD option other than the NAV DVD. Thanks. Will check it out.
Quick Reply: MP3 playback on Professional Stereo
