MP3 Disc - What to do in order to play them ?
My Ride: 2004 545i Automatic - Premium - 19" M166 - Logic 7 - No Nav
Hi,
I remember reading somewhere (wich I cannot find anymore) a way to make Mp3 disc to play in our regular CD player or 6 disc changer. I tried on my car but it says on the screen that the "media cannot be read".
Any advice ?
Thanks
Any advice ?
Thanks
Originally Posted by Mz3bo' post='335946' date='Sep 18 2006, 06:15 PM
Hi,
Any advice ?
Thanks
Any advice ?
Thanks
My Ride: G30 M550i
Model Year: 2018
Everything you need to know is probably contained in the following thread:
http://forums.e60.net/index.php?showtopic=24018
If it says Medium Cannot Be Read, then your car will read MP3s just fine, except you've burned it incorrectly. When you burn the disc make sure its burned as MP3 Disc instead of Data Disc. For example if you use Windows and use Nero, there's burning Data and MP3, make sure you select MP3 disc or it won't read. Do not burn by using the normal Windows Drag n Drop feature to burn the mp3 or it won't work. If you use Mac, then use Toast to burn an Audio MP3 disc, not data or the mac's burn folder. I learned this the hard way... 10 CDs full of MP3s and none of them work because I did it wrong. Cheers.. Hope its the same for you..
Originally Posted by JMB' post='336089' date='Sep 19 2006, 06:22 PM
No, this is the message if you radio is not mp3 enabled as well. My bus radio says that when I insert a mp3 disc.
Originally Posted by Mz3bo' post='336095' date='Sep 19 2006, 04:59 AM
Hi,
My car is a Canadian 2004 545i with Premium Pack and Logic 7. No Nav.
Thanks
Thanks
