Moisture in rear pass. footwell
Today I retrieved a book fromm my rear pass. footwell and it was wet. Came to find moisture on the carpet as though it was seeping in from underneath somehow. Any ideas on what it could be??
Thanks
Thanks
My Ride: E60 530d
do you have a sunroof?
Also, undo your pollen filters, lift up the plastic covers underneath that, and check near the brake servo for a puddle of water
Have you felt your front passenger footwell too? If its wet it may be your front storm/ebox drain...
My Ride: 05 BMW 530I
Definitely check your storm drains for clogging. If it clogged up clean it immediately because it can create a costly fix. One you will not be willing to do. After you check the drain check your door seal to make sure water is not leaking.
thesalboy
04-08-2015 09:13 AM
