Today I retrieved a book fromm my rear pass. footwell and it was wet. Came to find moisture on the carpet as though it was seeping in from underneath somehow. Any ideas on what it could be??
Thanks |
do you have a sunroof?
Also, undo your pollen filters, lift up the plastic covers underneath that, and check near the brake servo for a puddle of water |
Have you felt your front passenger footwell too? If its wet it may be your front storm/ebox drain...
Definitely check your storm drains for clogging. If it clogged up clean it immediately because it can create a costly fix. One you will not be willing to do. After you check the drain check your door seal to make sure water is not leaking.
