Key Memory for Seats???
Old Jun 11, 2006 | 06:07 PM
VTec's Avatar
Is there any way to have the car automatically adjust the seats and mirrors by which key is used to unlock or start the car? It properly recognizes the individual key used to set entertainment/volume settings, brightness, etc., but not seats or mirrors.
In fact, I can't find a way except to manually press and hold the 1 or 2 memory button after opening the car. Is this the only way? The manual leads me to believe it should work off key memory too.
Old Jun 11, 2006 | 06:42 PM
EBMCS03's Avatar
Mine does it.
Actually it works like this.
When you shut down the car it memorizes everything. The last setting before you shut the engine down. and when you unlock the car with the key it reverts back to the last setting no matter how it was changed.
Old Jun 12, 2006 | 12:56 AM
aybeesea's Avatar
Driver's seat and and side mirror positioning (on my software at least) is an IDrive option. From memory it's somewhere in the "central section" (system settings??) of the menu screen
You can choose wherther the moves happen upon unlock or upon door open.
Alternatively your keys should/could also have been programmed by the dealer at new (and colour coded) so that all appropriate settings (including seat and mirror positioning) were linked to each key. Subsequent programming is chageable.
ABC
Old Jun 12, 2006 | 05:22 PM
VTec's Avatar
ABC
Thanks much - I had gone through this option (actually it's under Door Locks/Central Locking/Last Seat Pos." - you were close) and had set it to "After Opening Door". I reset it to "After Unlocking" and it now seems to work. Not sure what was going on.
Thanks again!
ucsbwsr
Aug 17, 2015 06:56 AM
Bank$hot530
Aug 3, 2015 05:17 AM
JonathonK
Lounge
Jul 31, 2015 11:39 AM
ucsbwsr
Jul 13, 2015 08:24 AM
Island Road
Jul 9, 2015 10:13 AM
