Ipod Classic 160GB can only display 29 playlists.
Originally Posted by DoanThaiTu' post='764607' date='Jan 10 2009, 05:18 PM
no I don't have them I guess, I thought the cable that I use to connect my ipod to my car is the Y cable but it's not then. I was thinking about update Progman may do something for me but if you said it wouldn't then maybe not then. So the only solution is to go back to my older 60GB video, I really want more space that's why I got the Classic 160, but man did I make a mistake. Thanks for your help.
Originally Posted by DoanThaiTu' post='764555' date='Jan 10 2009, 03:04 PM
oh what happened? what you mean by "sacrificed"?
wowww, I really am sorry for what happened. but hey I found a great solution, I will try to use Playlist for only most listen Playlists only and the rest of my playlists will go in Album and Gerne instead. For some reason, I can access 255 Album and 255 Gernes so that's my solution. Thanks guys, still try to figure out way to resume my song after lock/unlock the car.
My Ride: 4-Wheel ABS• 4-Wheel Disc Brakes• 6 Cylinder Engine• A/T• Adjustable Steering Wheel• Alarm• Alloy Wheels• IDrive Professional Radio,NAV • Auto Trans Stick on Console• Auto-Off Headlights• Auto-On Headlights• Auxiliary Pwr Outlet• Brake Assist• Bucket Seats• Child Safety Locks• Clock• Compass• Console• Cruise Control• Daytime Running Lights• Driver Air Bag• Driver Illum. Vanity Mirror• Driver Info Center• Driver Vanity Mirror• Dual Climate Control• Dual Power Seats• Electrochromic r. view mirror• Electronic Stability Control• Fog Lamps• Front Floor Mats• Front Reading Lamps• Gasoline Fuel• Heated Driver Seat• Heated Ext. Psngr. Mirror• Heated Exterior Driver Mirror• Intermittent Wipers• Keyless Entry• Keyless Start• Leather Seats• Leather Steering Wheel• Maplight(s)• Passenger Air Bag• Passenger Vanity Mirror• Power Brakes• Power Door Locks• Power Driver Mirror• Power Driver Seat• Power Passenger Mirror• Power Passenger Seat• Power Rear Bench• Power Steering• Power Tilt/Sliding Sunroof• Power Windows• Psngr. Air Bag On/Off Switch• Psngr. Illum. Visor Mirror• Rear Air / Heat Ducts• Rear Defrost• Rear Floor Mats• Rear Shoulder Belts• Rear Wheel Drive• Steering Wheel Controls• Steering Wheel Radio Controls• Tachometer• Tire Pressure Monitor System• Traction Control• Trip Computer• Trip Odometer• Var. Spd. Intermittent Wipers• Vehicle Anti-Theft System• Window Locks.
HI I am not quite sure i understand the problem about Ipod not resuming after locking the car, but could it be that power source for the ipod is taken away when you lock the car (Ipod is hooked up to accessory which is only powered when the with the ignition in ACC).
I just got my 530I and am looking for a better solution than the one offered by the dealer, I am leaning towards the Dension Gateway 500 but need more info about the intergration.
to the forum!GW500 is great and much better than the OEM iPod such as no limitation and you get USB connection but the cost is twice as much and you still need the dealer to enable the GW500 either as CD changer or iPod interface in order for it to work w/ the iDrive.
bestofthebest
Mar 28, 2016 02:47 PM
DetailersDomain
Detailing Forum
Sep 22, 2015 03:59 PM
Bank$hot530
Sep 16, 2015 01:28 PM
