INPA & Ediabas install issues
My Ride: No BMW
Hello,
I am trying to get a code reading solution set up for my recently acquired 2007 530i.Build date is 04/2006
I have done a lot of searching around, but no real clear answer as how to fix this problem I am having in the install of the INPA/Ediabas software. I found this link: EDIABAS / INPA Installation Problem but after reading through it, it's like the original poster's question really wasn't answered. Maybe I don't "understand" the lingo.
I installed it to the C:\ directory in a folder called 'INPA'. That fixed some other errors I had from the start. Now I am left with the below issue:
The problem I am running into is that once it gets to the install portion of selecting "BMW Rectification group UK" as well as the USA version, tried the install both ways and I end with a screen that shows:
EDIABAS 6.4.7 (the check boxes are grayed out (complete and update))
INPA 5.0.1 (the check boxes are grayed out (complete and update))
The only option I can check is NCS Expert. I run that, it runs into a runtime error '76' and the installation closes itself out when you hit 'ok'.
I am trying to install this on a 32bit WinXP machine, bc that's what I have.
How do I get past this and fix it? What other options do I have for reading the codes in my car? I don't have any issues right now that I know of, but I do want to be able to use this or at least have some way to read codes in my car and change settings if I wish.
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
It seems like you tried to install it and messed up the process. Maybe it can be fixed by looking at a
. It is for windows 7 but if you look at it you should now how to do it. Make sure you have the install files on your C: drive
DavaiLave
08-02-2022 02:16 AM
rizwan1377
04-05-2015 05:22 PM
