INLINE 6er Vs V8 : better handler?
#81
Originally Posted by swajames' post='490525' date='Nov 5 2007, 09:50 PM
If you look at posts here on the forum from LCI 550 owners who had a pre LCI 545/550 there seems to be a consensus that the handling is sharper than their prior car. The pre LCI V8 cars had the same suspension setup (US sport, ARS, style 124 wheels and RFT's) as the new 535. That said, in my judgement the 300lb difference isn't as noticeable as you suggest and more to the point I doubt any of us push our cars hard enough often enough to truly get close to the real limit (doesn't matter whether we have a 535 or a 550, I suspect that in most cases the car has much more talent that we do as owners and drivers). BTW Porsche is indeed putting 19s on its cars, the Carrera S comes with 19's as standard.
The 550 with the same speed into a similar maneuver felt very heavy and I felt unable to throw it into a drift around a turn nearly as easily.
Now 500 pounds is a HUGELY noticable difference. Mine also has virtually no options and like I said tosse about 100 pounds of weight so probalby close to 600 pounds different than what I drove. It had nothing to do with the stiffness of springs, shocks etc-it was simply the lightness you could throw around corners.
The heavier car has more inertia and makes it harder to come out of various maneuvers
#82
My Ride: 2008 Sapphire Black on Black M5 - loaded sans soft close doors
Originally Posted by redwhiteblue' post='490522' date='Nov 5 2007, 07:38 PM
There is no room for debate here about handling. There is debate over which car is faster, better, sexier, more desirable, torquier whatever but handling nothing.
Plain and simple 300 pounds less weight equals superior handling. 19 inch tires mean nothing other than nicer looks. Look at a porsche-nothing bigger than 18s all around.
You can easily put non-runflats on the 535 so you cant count that.
If you think the 550 handles better what possible justification do you have? OBviously the tuned suspension is not noticable as many vets on here cannot tell any diff
So I think it comes down to a debate on handling and there really is no debate on which car is faster, more desirable, or torquier (sic).
#83
We are looking at how they come stock within reason. Changing to non-runflats is hardly an unfair comparison since virtually every owner that would push the car would be changing the tires. Yes you have to assume he keeps 18 inch wheels to keep most variables the same but comparing non runflats to non runflats is truly testing the cars handling and not factoring in an outside variable such as the rubber that happens to be attached to the bmw.
#84
or that they will change the 550 suspension to make it better....
so the only way to truly compare is stock IMHO
#85
Originally Posted by doug_999' post='490541' date='Nov 5 2007, 10:58 PM
ah but you can then argue that people will chip the 535 making it faster.......
#86
Originally Posted by redwhiteblue' post='490544' date='Nov 5 2007, 09:07 PM
You are going to compare chipping a turbo engine and changing the hp by 100hp to slapping some non-runflat tires on a car. Yes both are technically modifications but hardly analogous, give me a break.
#87
Originally Posted by doug_999' post='490565' date='Nov 6 2007, 12:20 AM
And yet both mods cost about the same.....strange....
Listen I am sorry you wasted your dough on a 550-its all good and maybe next time you will make the right choice
#88
Originally Posted by redwhiteblue' post='490572' date='Nov 5 2007, 10:36 PM
Dougie. You can think whatever you like-you are right, your on to something shhh-you may let everyone in on the big secret that tires will magically turn the 535 into a super car handling wise.
Oh but in December 2005 when I picked up the 550, there was no such thing as the 535.... but hey, since when are cars smart purchases?
Anyway, I've proven that there is debate on handling for these two cars and you have proven that posts about the 535 and 550 generate inconsiderate posts that lead everyone to get sick of threads like this really quick.
buh bye...
#89
Originally Posted by doug_999' post='490577' date='Nov 6 2007, 12:50 AM
ahh but see? You can go check my posts here and bimmerfest where I clearly think the 535 is a better buy and given the choice today I would evaluate both cars carefully.....
buh bye...
buh bye...
1. Brilliant analogy that putting non-runflat tires on a 535 effects handling similar to how chipping the 535 with 100hp effects performance engine wise. So putting non run flats will increase handling by 33 percent basedon your analogy
2.You pointed out 2 completely different mods are the same price. The ipod retrofit kit is in that price range-maybe we should only compare cars with the Ipod kit installed to be fair in your eyes. The weight difference and power drain from the ipod may effect performance and handling
#90
There is no doubt that the extra weight on the front wheels of the 550i negatively affects the handling. It?s something like an extra 200 pounds in the front. This has to give the front end of the 535i a better feel. Its basic handling 101. Even if the 550i has a little stiffer suspension, it?s not enough to overcome 200 pounds.
But to me there is no argument, I would much rather have the 550i.
