Impressed with the TPM
Old Aug 12, 2008 | 11:22 AM
ugggh's Avatar
Originally Posted by juris335' post='644887' date='Aug 12 2008, 10:52 AM
Mel- Was your flat a RFT? If I get a nail in a RFT can it be repaired or must I replace with a new tire? Can most shops fix/repair a RFT which has a screw or nail in it? Thanks Pat
I had a screw in one of my RFTs - pulled it out and patched it with no problem. That was probably 10k miles ago. I believe as long as it's not too close to the sidewall you're fine.
I really prefer the Porsche TPM system since it gives you the actual psi number for each tire.
Old Aug 12, 2008 | 11:25 AM
Ricracing's Avatar
Originally Posted by jmsod' post='644674' date='Aug 12 2008, 03:04 PM
On the way home from a party on Sunday night, I get in and get the "low tire pressure" left front tire on iDrive. I pull into the gas station and look at the tire. It looks fine. I check the pressure and it reads 29. (I run 32 in the front) I was pretty impressed that the TPM could pick up a difference of 3 lbs of pressure. Gotta love this car!
It is, but sometime even too sensitive.
Mostly in the winter time, though.
One should check out the tire pressures once a month!
Old Aug 12, 2008 | 02:28 PM
melimel's Avatar
as these guys said.. not sure about the run flats if there dif as far as patching and all.. or if they need to be replaced totally.... mine are not run flats
i could have patched it.. but i had the insurance and decided to get the new tire.. which ended up getting me a new rim as well.. but thats another story..lol.. in all honest i would patch it.. and keep on trucking..lol..
Old Aug 12, 2008 | 03:53 PM
jmsod's Avatar
Originally Posted by juris335' post='644691' date='Aug 12 2008, 09:07 AM
Do you have RFT? Did you have a nail in it? If not, why do you think you lost 3 lbs in one and none in the others? Thanks.
Yep, I have RFT. I simply have not had time to check it out. There may indeed be something in the tire.
Old Aug 12, 2008 | 04:01 PM
Gene's Avatar
550i with sport pckg comes with 172's and conti's, non rft's...
Old Aug 13, 2008 | 12:11 AM
littlemouse's Avatar
My Ride: Week 17 Build, 2008 E60 535d M Sport - Titanium Silver, Black Dakota Leather, Visibility Package, Media Package, Automatic gearbox, Steering Wheel Heating, M Double Spoke 172 19" Mixed Wheels, Auto-Dim+Exterior Mirror, Comfort seats, Front Seat Heating, Aluminium Pentan interior trim,DAB Tuner, TV Function, BMW Individual Audio System 825W !!
I beleive the reason they don't advocate repairing runflats, is the possibility of damage to the side wall, being caused by 'running flat'. the tyre repairers do not know how far the tyre may have been run with zero air pressure in.
I think there is some confusion about this, as back in 04 when I had a puncture, no one would touch the tyre for repair, the just did what the manufacturers told them, i.e. Replace the tyre. Maybe because they were relatively new back then. But since then I even had my Dealer repair the tyre, so long as it wasn't to near the side wall. Though to be fair when I questioned the mechanic about being able to repair them, he said it was now okay to repair apart from one make, can't remember which one though, sorry.
Old Aug 13, 2008 | 09:12 AM
AlexFW's Avatar
Model Year: 2005
Originally Posted by GENEaTALS' post='644892' date='Aug 12 2008, 07:57 PM
Hard to repair an RFT from what I have read...
I drove for a year with 2 RFT repaired, on my Mini Cooper S: not any trouble.
Old Aug 13, 2008 | 09:14 AM
AlexFW's Avatar
Model Year: 2005
Originally Posted by GENEaTALS' post='644712' date='Aug 12 2008, 04:12 PM
Yes, signal for every wheel...
Wow, technology
Old Aug 13, 2008 | 03:26 PM
senorfrog97's Avatar
Mine went off - my front right tire was slowing loosing pressure - turns out it's a hairline crack in the wheel
alexbaldy
Sep 28, 2015 12:28 PM
carid
Sep 10, 2015 06:39 AM
05Mdriver
Aug 24, 2015 05:41 AM
TMK
E60 M5 Discussion
Aug 18, 2015 01:32 PM
ey2001
Aug 7, 2015 04:15 PM
