Impressed with the TPM
Old Aug 12, 2008 | 04:04 AM
jmsod's Avatar
On the way home from a party on Sunday night, I get in and get the "low tire pressure" left front tire on iDrive. I pull into the gas station and look at the tire. It looks fine. I check the pressure and it reads 29. (I run 32 in the front) I was pretty impressed that the TPM could pick up a difference of 3 lbs of pressure. Gotta love this car!
Old Aug 12, 2008 | 05:07 AM
juris335's Avatar
My Ride: BMW 535xi
Do you have RFT? Did you have a nail in it? If not, why do you think you lost 3 lbs in one and none in the others? Thanks.
Old Aug 12, 2008 | 05:18 AM
AlexFW's Avatar
Model Year: 2005
Mh ?
Do new E60s have the signal for every wheel ?
Old Aug 12, 2008 | 05:35 AM
melimel's Avatar
i had my TPM tell me i was about 5 lbs low immediately after i got the car.. on my back right tire.. about once a month.. till finally i had a flat.. had a screw in it.. makes me wonder if it was there all that time and after a while.. my poor tire gave out.. ended up getting a ne tire..
but i do agree the TPM is sensitive even to a couple of pounds of pressure.. IMO
Old Aug 12, 2008 | 06:12 AM
Gene's Avatar
Originally Posted by AlexFW' post='644696' date='Aug 12 2008, 06:18 AM
Mh ?
Yes, signal for every wheel...
Old Aug 12, 2008 | 06:44 AM
bigbadbull's Avatar
My Ride: 2010 VW Passat Wagon 2.0l Tsi Grey/Grey Budapest 18" Lost to HPFP issues: 08 535i sport pkg Lost to Dreaded E61 Sun roof leaks: 07 E61 530Xi
I had my front left one trip with about 4 -5 lbs low, took the wheel off to look for a nail, or leak. Did not find one even after putting in a tank of H2o. On my audi you can adjust the sensitivity of the sensors.
Old Aug 12, 2008 | 07:49 AM
littlemouse's Avatar
My Ride: Week 17 Build, 2008 E60 535d M Sport - Titanium Silver, Black Dakota Leather, Visibility Package, Media Package, Automatic gearbox, Steering Wheel Heating, M Double Spoke 172 19" Mixed Wheels, Auto-Dim+Exterior Mirror, Comfort seats, Front Seat Heating, Aluminium Pentan interior trim,DAB Tuner, TV Function, BMW Individual Audio System 825W !!
I've seen the pictures on the i-drive on the US models, where it shows an image of the car plus the four tyres, showing green when everything OK. But, on my UK model, and also on my old E61, when you go to the TPM screen, it just says 'ACTIVE'. No picture or anything. Plus when you get a puncture, as I did in the E61, it just flashes on the screen 'PUNCTURE'. Then when you go into i-drive, it just says the same thing, it doesn't tell you which tyre or anything.
Am I doing something wrong? Can i change the setting, or is it another one of those U.S v UK model differences things.
Old Aug 12, 2008 | 08:27 AM
Gene's Avatar
not sure, I had an error a few months back, the screen with all four tires showed, the one with low pressure showed yellow instead of green...turned out it was just 5 psi short vs. the other tires....
Old Aug 12, 2008 | 09:52 AM
juris335's Avatar
My Ride: BMW 535xi
Mel- Was your flat a RFT? If I get a nail in a RFT can it be repaired or must I replace with a new tire? Can most shops fix/repair a RFT which has a screw or nail in it? Thanks Pat
Old Aug 12, 2008 | 09:57 AM
Gene's Avatar
Hard to repair an RFT from what I have read...but think american tire co does repair RFT's, but it can only be repaired once....most of the time you just gotta bite the bullet and replace the tire...
