iDrive Stuck
My Ride: 2005 BMW 545i
Black sapphire metallic
Black dakota leather
Sport Package
Premium package
Cold weather package
Navigation - Logic 7
I went to turn on my 545i this afternoon and the bmw screen came up like normal, but then it was stuck on the FM radio screen. I couldn't control anything in iDrive. NAV and radio would not work and the time/date was reset. A couple miles later the tire pressure warning indicator came on...
Does this sound like a CCC failure???
Sport Package
Premium package
I came back home and turned the car off...waited 30 minutes, turned the car on and i-Drive came right up, radio and NAV as well!
Weird...do you guys think this was just a reset thing?
I'd start with a check on the battery ... When they start to die it seems that all sorts of error messages begin to pop up!
That said, and my car has TPMS not FTM, on one occasion that my tire pressure was low and set off an alert, I seem to recall that it took over and temporarily locked out some idrive functions.
With a 2005, you have to turn the key, right? I am careful in my 2004 to pause after each click of the key so that the electronics power-up smoothly. I feel that rushing all the way from OFF to CRANK does not give all the systems proper time to power up. Yea, it takes a little longer to get the motor going, but I believe it is better for the electronics. Go ahead, call me crazy.
Sport Package
Premium package
My Ride: ActiveHybrid - fully tricked out
Model Year: 2013
Sounds like the the battery might be going. I had my battery replaced just over a year ago after things started to act up like you describe. Given that my car is a year older than yours and that we live in similar climate, then it makes sense that you might be due.
Good luck on that one.
@SilberGrauE60 - I've noticed that as soon as I hit the unlock button all kinds of motors and gears start to quietly whir before I even open the door. I figure they're doing things like getting the fuel up to pressure and whatever else is required for liftoff. Then I crank the key over and don't worry too much about how quickly I crank it. Although I'm not foolish about it.
Cheers
Cheers
