iDrive Hidden Menu
My Ride: Bmw 530d 2004
Here you go: Hidden menu
The guide says the ignition must be turned on, but at least I can get into the hidden menu even if the engine is running.
The coolant temp is shown in the folder 7.
I hope this helps!
- Antti -
I hope this helps!
- Antti -
One thing yet... it's not the iDrive menu, it opens in a small screen between the speedometer and tachometer.
There's not much you can actually do with the menu, but lots of more or less useful info is available. Like the coolant temp for example...
In that case you should leave it alone.
My Ride: 2000 540i/6: Silver
Model Year: 2000
will def leave it alone
My Ride: E60 2005 530d MSport. Media Package. Cream leather heated seats. Falkens.
Thanks for the information.
Will probably use it to verify the temp, and then leave it alone forever!!
Cheers.
Cheers.
Bank$hot530
09-16-2015 01:28 PM
