idrive crash and restart?
Originally Posted by cobradav' post='388628' date='Feb 7 2007, 10:31 PM
A little of everything on this one. I had the symptom, thought it was this:
SI B 84 08 05
Phone, Navigation Systems March 2006
Technical Service
This Service Information bulletin supersedes S.I. B84 08 05 dated January 2006.
designates changes to this revision
SUBJECT
CCC - CID Switches Between BMW Banner and Blank Screen
MODEL
E90, E91 (3 Series) with SA 609 Car Communication Computer (CCC)
E60, E61 (5 Series) with SA 609 Car Communication Computer (CCC)
E63, E64 (6 Series)
SITUATION
The customer may complain that the Central Information Display (CID) switches between the BMW banner and a blank screen (resets). One of the following fault codes is stored:
CID FC "A468 LVDS cable break"
CCC-BO FC "A3E4 fault in file system"
CAUSE
CCC Failure
PROCEDURE 1 (CID FC A468)
On a customer complaint basis, submit a PuMA case to the Electrical Group along with FASTA data.
But turned out a PROGMAN upgrade did the trick with NO CCC replaced. No one answer, but get it to the dealer.
Also for the cold theory we have this:
SI B 84 08 06
Technical Service
This Service Information Bulletin supersedes S.M. B84 240 04 dated December 2004.
SUBJECT
CCC Navigation is Inoperative at Low Ambient Temperatures
MODEL
E60 (5 Series) with SA 609 (CCC Navigation)
E63, E64 (6 Series)
Vehicles produced from June 1, 2004 up to November 30, 2004
SITUATION
The customer states that "Please wait..." appears in the navigation screen and the navigation system is inoperative at ambient temperatures below 37?F.
All other menus (Communication, Entertainment, etc) can be operated using the controller without any problem.
After the electronics unit has warmed up, the Navigation system starts working.
CAUSE
DVD drive failure at low ambient temperatures.
PROCEDURE
Replace the DVD drive as per SI B84 12 04.
SI B 84 08 05
Technical Service
SUBJECT
MODEL
E63, E64 (6 Series)
SITUATION
CAUSE
CCC Failure
SI B 84 08 06
Technical Service
SUBJECT
MODEL
E63, E64 (6 Series)
SITUATION
CAUSE
PROCEDURE
Thanks for the help guys, booked it in for a diagnostic. As its still under warranty do i get charged for the diagnostic check?
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
Originally Posted by daMANiack' post='388720' date='Feb 8 2007, 03:05 AM
Hi,
Don't know if this will help, have to tried disconnecting the battery (-) lead for at least 10 minutes.
I think you'll loose the date, time and maybe have to initialise the Active Steering, but it may reboot the system and clean out any gremlins.
Cheerz
Cheerz
My Ride: G30 M550i
Model Year: 2018
http://forums.e60.net/index.php?showtopic=25869
As far as the spontaneous reboot that papereyes experienced, cobradav's post looks pretty on target but keep in mind that earlier versions of software also had an issue with the CCC simply bombing and locking/rebooting itself. If it happens often at low temperatures, it's likely that the DVD drive is failing (per cobradav's post) but if it happens randomly, you might need a software upgrade...
Originally Posted by Rudy' post='388785' date='Feb 8 2007, 10:15 AM
Maybe I'm wrong but it looks as if papereyes thinks katheikia was kidding around about with his comment but in reality, E60's with Nav do have a control-alt-delete function built into the system to reboot the iDrive system without restarting the car.
as always with this great forum, theres a great wealth of knowledge,
As the car is still under warranty and only got it less than 30 days ago, i'm thinking of bringing it in to the dealer, as I would like to know what CIP version get an upgrade on the CIP as well.
if no joy i'll be ctrl alt del -ing
EuropeanArtz
Sep 23, 2015 08:21 PM
Claudiupromotion
Sep 17, 2015 08:02 PM
