Idling, Rough startup issues
After replacing those vanos o-rings with the teflon ones, i do actually noticed increased performance. It's more pedal-responsive and it moves. I like it!
Wondering what else I can do...any more seals/o-rings on this vehicle?![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
<div></div><div>ok i forgot to update about the fix...you see the flap? well it's supposed to stay 'opened' and is closed electronically. There is a part that looks as if there is supposed to be a nut inside of it. Just look at the bottom of the flap. What I did was I opened from the bottom with a flathead screwdriver and the yellow piece comes right out as soon as you loosen the lock washer from the mechanical arm. I affixed a self tap bit with a perfectly sized head that would fit right into the flap in the hole with the nut sticking out so the flap could rest on it..... and fitted it to test. After I verified all fit correctly I put epoxy (JB Weld) in it then put it back together and let it sit 24 hours. After verifying its strenght and integrity I sealed the flap AND the outer walls of the arms with RTV gasket sealant and let it dry for about an hour. I made sure everything fit and lined up and then I threw it back in.....put the car back together and voila! Vroom vroom!</div>
My Ride: Numero Uno in Richmond Va 04 530 6 speed, jet black, black dakota leather, xenons, red rear reflectors, 545 front grill, cold weather package, premium package, staggered 19 inch BBS rxII/michelins, H&R coilovers and intergrated, R1 concept drilled an
Engine: 530i
great fix and find, but that is why i stated in my comment that even without my help you would have found the problem.
By the way did you takr pics of the modded valve
![Worthy](https://5series.net/forums/images/smilies/imported/worthy.gif)
My Ride: 08 LCI 535i sport M5 umnitza full kit, Maya RM 1 245/35/20 20x9 et16, 275/30/20 20x10.5 et17, Future mods- KW coilovers V3 and StopTech brake
You're the man. Great troubleshooting and fearless attitude about tackling the car head on.
No i did not take pics but while the paint is drying tomorrow (well later today) i may take it out....I think you guys deserve some pics lol....i just got excited and forgot about technology for a bit
Hi, I have a 2004 525i, It sounds like i have the same problem you did but am not sure. My check engine "increased emission" light came on when i was driving and now my engine has rough idle and i can kinda hear a air leak in the engine's left side and also when i turn it off i can hear a real loud air leak. autzone read the code and it was "vacuum leak". can you help me? thank you
My Ride: 545i
That site with the teflon seals only addresses 6 cylinder engines. I have a v8. Are the vanos similar? I know the v8 is a double setup but are the problems the same?
md750i
04-08-2015 06:08 AM
