I think my fan has failed...
#31
My Ride: 530i
Engine: M54
I'm not talking about faults on the ECM and IHKA. I mean i love playing around with coding in our cars i'm sure you do too. maybe there is some setting that you changed that is causing your fan issue. Thats why i'm saying try reset coding it. I'm sure i've seen fan value settings while coding.
#32
My Ride: 545i
Any luck replacing the fan?
My 2004 545i with 66k miles has a fan that isn't spinning at all. Fuses OK, no codes.
The E60 is new to me so I'm running blind here. Any thoughts as to what I could check? Thanks.
#33
My Ride: 530i
Engine: M54
yes I replaced my fan. all is well.
there is no outboard relay for the fan. if the fuse is OK, your fan is likely toast. speed is controlled by a PWM signal directly from the ECM, so there really isn't much to check. if you have access to INPA, DIS, or even a multimeter that can measure a PWM signal you can check to see if the PWM signal is present. if you don't have access to any of these things you can roll the dice and replace the fan. they're not cheap, and failure is not uncommon.
good luck.
good luck.
#34
My Ride: 545i
Kyle, thanks for the update, I appreciate it. I like your explanation about how simple the circuit is (and in some ways thats good, I suppose). Where did you get your replacement? I've found a few sources and one for a somewhat reasonable ~$250 that I might go with. Again, thanks.
#35
My Ride: 530i
Engine: M54
#37
My Ride: 545i
OK, I replaced the fan and no dice; still isn't working. I probably should have changed the sensor first, but for some reason I just didn't so now that's next. Stupid.
#38
My Ride: 530i
Engine: M54
Take it to a shop and have them check for PWM signal at the fan connector. Also don't kick yourself for replacing that fan; it was 13 years old, and you may have just prevented yourself from getting stranded.
BMWs seem to be getting more and more complex with more and more parts that can be replaced for preventive measures. My E30 gets a new timing belt and water pump every 4 years; I don't wait for the belt to snap or the water pump to let go, I do it so I don't end up on the side of the road. These electric cooling fans seem to fail almost without warning, especially as they get old. True, it didn't fix your problem, but at 13 years old it was on borrowed time.
Again, check for PWM signal at the connector. shouldn't cost you much to do that. good luck, please report back when you get this resolved.
