how to tell current daten version?
My Ride: BMW e60 525d
Hello. 9185627 to 9185636
Why did you block out the last 7 of your VIN? lol
From your UIF it looks like you already had some programming done to this car. The yyyyy indicates that those units do not have your VIN or were wrote to incorrectly.
Did you have your MULF replaced?
If you want to reflash something with the current ZB number you can do that. You can put the flash on the unit and if it doesn't work you can just flash it back to the old one.
But again, I will ask the question.......Why are you doing this since you have a 2009 flash? Should work fine with the CIC as long as it's the same part. Why don't you just put the CIC controller in, load up NCS and do a process all to encode it to your car before thinking of a flash? For your car there is probably no newer update besides the one you have.
The UIF is not going to show you the daten file version. It only contains the ZB numbers.
As a rule, always use the highest daten files available.
umnitza
09-02-2015 11:28 AM
