How do I clear the brake pad replacement warning ?
My Ride: 545i sport
You can check the sensors easily enough by doing a simple circuit continuity test. The sensor is a wire nothing more. If wire is cut (by brake rotor), brake pad wear warning is triggered. The sensor completes the warning light circuit to ground. When the wire is cut, ground is lost and the warning is illuminated.
It was my belief that upon sensor replacement, it takes several ignition on/off cycles before the fault clears itself unless the fault is cleared manually with INPA or similiar.
My Ride: .
Model Year: .
I suggest going through the reset procedure again.
I've heard that on these systems and if / when it's a safety item, and it goes a certain distance etc past the resetting range it can no longer be reset by using the method that was posted earlier, it will have to be reset with with BMW software. I would go by an INDY shop and see if they can do it for you. I am sure they dealer will not since they did not change the breaks.
TexaZ3
05-06-2015 09:54 AM
