Hong Kong E60 sub-Forum
Old 06-29-2011, 06:43 PM
  #33341
kcleung's Avatar
think its somewhere between lijiang and chengdu, I looked at the route when I submitted my application for bmw destinationX last year.
Originally Posted by keith84_uk
Maybe a stupid question, but where is Shangri la? I mean the real place, not the hotel
Old 06-29-2011, 06:51 PM
  #33342
kcleung's Avatar
from wikipedia:
Panamera Diesel
The Panamera Diesel was launched in May 2011. The vehicle uses the same 3.0L V6 engine used in the Cayenne Diesel, itself a tuned carryover of an existing Volkswagen engine. The Panamera's engine has a power output of 250 bhp (186 kW; 253 PS).
it would be politically incorrect for porsche to charge more than 1 w real porsche engine,think the current petrol v6 is also from vw.
Originally Posted by pinguhk
that sounds about right.
all eco cars cost more than petrol cars :thumbsdown:
I bet it is faster than most of our cars at TMS
Old 06-29-2011, 07:11 PM
  #33343
Jacky328's Avatar
you should get this too.
you do over 250k km a year so sell the F10 to Kieth and get the Land Rover and a 1M
Sounds good idea
Old 06-29-2011, 07:20 PM
  #33344
pinguhk's Avatar
My Ride: Mini Cooper
Originally Posted by ricky1329
I said how come made a N/A car up over 25% in power ? Kenji's one is a turbo car. FJ
that easy change the bit inside the engine.
like the e90 2.0 which is over 275 bhp with no turbo just a 2-litre four-cylinder in-line engine
Old 06-29-2011, 07:43 PM
  #33345
wnshie's Avatar
Guys, need a little help, I found "Redline Water Wetter" that seems to be promising on treating my overheating problem and found a dealer on 13 Ha Heung Rd, Tokwawan called Kam Kwun (??????????13?), since I have to have meeting till late, can anyone help me buy 2 bottles of such? I will pay you back right away tonight at AK's, or AK ????????????
??? Additive
?????? Premixed
either is fine ?????ok
Thank you thank you
Old 06-29-2011, 07:51 PM
  #33346
keith84_uk's Avatar
My Ride: BMW E60 530i , Silver with leather Air Con iDrive 17" Breyton Rims with Dunlop Sp Sport tyres (M-Tech Bodykit and rims WANTED) Alfa Romeo 147 TS1.6 , Black with Air Con 17" Multi Spoke alloys with Bridgestone RE040 tyres Toyota MR-S 1.8 VVTI , Lagoon Blue with Red leather Air Con 15" standard alloys with Toyo tyres Toyota Celica 1.8 VVTI, Lagoon Blue, Air Con, 16" Standard alloys with Kuhmo KU31, EBC Green Stuff
??? Additive
?????? Premixed
Thank you thank you
I might be wrong, but using aftermarket coolant might void your warranty,
and if your car did overheated and caused faulty part, am sure porsche will blame for the coolant and not fixing for you.
Jsut my 2 cents
Old 06-29-2011, 07:54 PM
  #33347
keith84_uk's Avatar
Whats that?? i never heard BMW makes 2.0 NA with 275bhp on E90??
Old 06-29-2011, 07:59 PM
  #33348
pinguhk's Avatar
??? Additive
?????? Premixed
Thank you thank you
kenji was asking about this too, I will get this and try it out.
maybe get the big 1 and we can all share the cost.
Old 06-29-2011, 08:04 PM
  #33349
wnshie's Avatar
Jsut my 2 cents
Thanks for your 2 cents , but overheating is a known issue with the Panamera all over the Porsche forums, Porsche will add another radiator to the 2011 made Panamera to help cool down the car... also this stuff is commonly used in USA/UK for Porsche at 70/30 water/ww(water wetter) for drivers who gets the same problem while keeping the car at high rev for a prolong period...
Old 06-29-2011, 08:05 PM
  #33350
pinguhk's Avatar
Length: 4,535 mm
Width: 1,845 mm
Height: approx. 1,350 mm
Wheel base: 2,763 mm
Vehicle weight: 1,140 kg (with driver)
Engine type: four-cylinder in-line
Capacity: 1,998 cc
max. output: approx. 275 bhp at approx. 8,400 rpm
max. engine speed: 8,500 rpm (as per regulations)
Cylinder block: aluminium crankcase reinforced with a bedplate
Engine control: BMW Motorsport ECU404
Tank capacity: approx. 45 litres
Fuel: standard fuel, Super Plus unleaded
Chassis/body: unitary construction steel body
Aerodynamic front apron, rear apron, flared front and rear
package: wheel arches made of CRFP/GFRP, rear wings made of aluminium
Front axle: double joint Mc Pherson axle with adjustable anti roll bar
Rear axle: five arms axle with adjustable anti roll bar
Shock absorbers: Sachs with adjustable compression and rebound
Brake system, front: four-piston AP brake callipers, iron brake discs of 332 mm diameter
Brake system, rear: two-piston AP brake callipers, iron brake discs of 280 mm diameter
Wheels: aluminium rims, SA 216 BBS
Seat: Recaro ProRacer HANS
http://www.e90post.com/forums/showthread.php?t=4328
Quick Reply: Hong Kong E60 sub-Forum
