Hong Kong E60 sub-Forum
Old 05-23-2011, 07:42 AM
  #32741
bbl
bbl's Avatar
My Ride: 525i
i have not replace with my new seal yet.
i did initialization my sunroof at lunch time.
when i drive my car after work, no ac on, only the lowest fan on, no window open, no hifi. i drive like this at least 10min. speed at 80-90km, no wind noise. or it just very very little.
when i run at over or about 100km, abit of wind noise start.
still alot less compare to the time when Ricky drive my car last time.
i guess, the 1st time when bmw do the initialization, it was with a new seal, after few years, when the seal gets old, the sunroof need to re check for new position again.
the initialization is automatic, nothing i can do but only wait.
put key in
hit ""start"" once without foot on break
hit and hold tilt till it gets to position A
hold at tilt wait about 5-10s
sunroof rise to position B
continue to hold
sunroof automatic back to the close position and fully open and close.
then u are done.
and now, i wasted my new seal. hehe
maybe i just keep it.
when i compare the old and new seal, it is not fresh enough.
i will change it later when i have time.
Old 05-23-2011, 04:38 PM
  #32742
pinguhk's Avatar
My Ride: Mini Cooper
Originally Posted by mark_hk
If you check the forums, alot of ppl have the issue with the noise and wind buffeting from the sun roof......
Alot of ppl also replaced seals...
bbl did not replace the seal and fix it last night.
But if you what you can buy the seal off bbl he has 1 and no need to install now.
Old 05-23-2011, 04:40 PM
  #32743
pinguhk's Avatar
Originally Posted by bbl
please check if it can be open
thanks for posting I will do this when my car gets abit older.
glad that you fix the wind on your sunroof.
Old 05-23-2011, 06:57 PM
  #32744
bbl
bbl's Avatar
My Ride: 525i
i guess u can try to do it now, as the rubber had already get older after some time.
just cf itchy
hehe nxt time i run over 100 to see how is the noise.
just till up my sunroof this morning, and close.
let see how it goes when i drive after work.
Old 05-23-2011, 08:20 PM
  #32745
billhk's Avatar
My Ride: carbonized MB coupe
this problem is not whether the car is new or old, it is a common fault from NEW,
thats from my experience.
Old 05-24-2011, 03:01 AM
  #32746
pmotoring's Avatar
My Ride: 2006 530i M-sport
yes please do replace it this weekend!!!
we all what to know if it will fix the nosie from the air passing over the sunroof.
My E61, E60 and E91 have terrible wind noise too, if I close the shade of the roof the woind noise would be gone
Old 05-24-2011, 03:03 AM
  #32747
pmotoring's Avatar
Guys, please advise how to reset the gear box ECU, can you just do some trick or need a hand held OBD de-corder to do so.
  #32748
mark_hk's Avatar
Yes, think its a design fault... quality of seals are not too good either?
Old 05-24-2011, 03:12 AM
  #32749
pmotoring's Avatar
I have my lights proffesionally washed and polished, It was like all cracked and old. Many people tell me it is impossible to restore to its original stage. Here is the result, looks brand new.
Old 05-24-2011, 04:10 AM
  #32750
bbl
bbl's Avatar
My Ride: 525i
How to do it?
Thanks
Quick Reply: Hong Kong E60 sub-Forum
