HELP sport shifter not working!!!!
My Ride: 2007 e60 530i
I do not have paddle shifters. I will take the center console apart this weekend to figure it out hopefully it's just the ribbon. By any chance do you have the schem of the shifter? I had to locate the how to get to those ribbons and it showed the e39. Still dont know how to remove the shift handle....
My Ride: BMW 550i M Sport
Model Year: 2010
Engine: 4.8L V8
To remove the shift handle pull straight up with all your might! It sounds crazy but I have an 07 530i also and that's how I got mine off when I pulled my CCC to do my audio upgrade. It will come off as long as you don't have weak little string bean arms .
Does it need to be in Neutral or can it be in any gear?
Model Year: 2010
Engine: 4.8L V8
My Ride: Bmw E60 530d
hey. did you solve your problem ???
i have the exact same problem. but mine came after i was trying to retrofit the M Paddles.
maybe i broke something ?? :-S
hey. i tried with a new shift plate, and it still dosent work. so its not that.
some people say that there is a switch on the gear lever. maybe its that one ?
After I went throught all of the trouble shooting in the previous posts (inspecting cables), I had the center console shifter replaced. I don't have paddle shifters so that could possibly be something else. My recommendation is to save yourself a headache and buy a used functioning shifter if you can. I saw 1 on Ebay for $125 and other BMW junk yards. Good Luck to you!
Awest91
09-17-2022 11:05 PM
TexaZ3
05-06-2015 09:54 AM
Mihainede85
03-11-2015 09:45 PM
