HELP! Shimmy, Vibration, Twitch, Wobble...BMW 530XI
Please Help! I am at the point where I have tried everything and get figure out why steering wheel shimmys, slight vibration, twitches.
When driving at 50mph up to 65mph my 2007 BMW 530XI AWD, has a slight annoying steering wheel shimmy, vibration... Also when steering side to side at those speeds and when coming out of a turn you feel a slight twitch, kickback I guess.
I have replaced the following so far;
New Tires,
New Rims,
New Rotors and Pads All around
New Outer Tie Rods
New Ball Joints
New Thurst Arm Bushings
In Addition when applying the brake at those speeds of 50-65mph the wobble vibration instentsifys.
Any suggestions of opinions would be much appreciated
New Tires,
New Rims,
New Outer Tie Rods
New Ball Joints
My Ride: 08 528i
I'm just starting to look at a shimmy as well when I apply my brakes, it's annoying, I noticed it more after I got new tires, I'll have the tire shop check them again, in my case I may have warp rotors, but one thing I want to point out, I've recently replaced the linkage between the steering wheel and the steering rack and the steering felt a lot more solid. This could be your problem... when standing still, move your steering wheel rapidly left and right and see if you notice a clunking/shimmy
My Ride: 08 528i
Here's the link to the steering lower joing assembly
https://5series.net/forums/topic/116...joint-assembly
JDeezyNYC
29
10-15-2020 11:48 PM
