HELP!!! Replacement CCC No Audio
My Ride: 530I
Model Year: 2005
![Angry](https://5series.net/forums/images/icons/icon8.gif)
Hi All,
I have a 2005 530I and my CCC has finally died.. (Moment of Silence)
The car is equipped with Logic 7 Audio and Voice Commands.
since I don't plan on having the car that long it doesn't make sense to go for the CIC retrofit. I got a great deal on the 6 memory button CCC that came equipped in the early 2008 LCI models before they got the CIC.
As we all know the hardware is plug & play which is simple as pie. the unit works and doesn't cut off as the previous one did. the issue is there is absolutely no sound.
I figured this could be because I need coding the CCC didn't have the L7 options in the settings so I figured the unit was currently driving the audio through the internal amp and with coding it could be switched to use the L7 amp in the trunk.
I had a very nice fellow who has done some coding in the past for me code it.
now the vehicle and the CCC are in sync and I even have the L7 options in settings but still no audio.. He coded
- CGATE
- CHOST
- CAUD
- CTUNE
- CAPPL
Im not sure what was done as I'm not familiar with coding
just to test I reinstalled my old CCC and while it was stuck on the BMW Logo and wouldn't boot I still heard the key in the ignition, door and seatbelt chimes so my amp is still working. My Voice Command buttons also do not work
Can anyone please help this is driving me nuts..
Thank you
- CGATE
- CHOST
- CAUD
- CTUNE
- CAPPL
Thank you
