Hello guys! I need a little help here,its inside the hood
My Ride: 2004 BMW 530I, K&N CAI, M-tech front bumper, Sprint-booster, Silver Hella taillights (vehicle is under construction)
it happens only at idle, it looks like the alternator is sucking a pretty lots of power from the engine or some amount of fluids got to the engine combustion chambers. I'm not sure if one of you guys ever experienced driving a car that just got the engine flooded with water, but if you ever experienced it, the vibration in my car right know is exactly the same as that.
Check around the engine for signs of leaking, if there is leakage around the heads - your head gasket is done and driving it is beyond dangerous to the engine. If there are no leaks, I'd get it checked anyway and then check the motor mounts and the pulleys, if the harmonic balancer is broken you get bad vibration too.
timmay77
09-24-2015 09:38 AM
ucsbwsr
09-19-2015 10:58 AM
umichchris
09-10-2015 12:54 PM
