Handling/suspension question
Originally Posted by IceyTys' post='759862' date='Jan 5 2009, 01:54 PM
Easiest and cost effective way would be to add springs, stiffer shocks and then finally strut braces. Also you can add spacers to your rear wheels, If I am not mistaken 12mm is the most popular size folks on here use with your set up.
New shocks and springs will make the biggest difference. H&R and Eibach make most of the equipment you need.
I would say you are going to spend about $1000-$1200 or so for the above additions for parts and labor if you added all of the above.
GL
GL
Do what this man says. I have an 04 530 and did all of those mods and more and WOW what a difference.
Whatever you do, make sure you get shocks and struts put in the same time you get sport springs or you'll regret it later. Trust me.
My Ride: 05 545i 6MT
If you are keeping your car longer, then it's ADVISED to replace the struts all together.
Labor rate (or DIY) on E60 suspension isn't cheap/easy.
For me H&R Sport w/ Bilstein Sport would be my preferred combo.
I have had many "floating" feel w/ Eibach Spring from many different cars that I have had but never any complains w/ H&R.
Koni struts are NICE but the rears can only be internally (not externally) - so what's the point of going "adjustable" if you have to remove rear spring to adjust then redo 4 wheel allign to get the "right" adjustment.
As for swaybar, I'm sure sport package comes w/ stiffer or "electronically adjustable" bar which makes a HUGE difference in handling when you drove the 550 w/ SP vs your non SP 530.
This is one thing to consider too. Many aftermarket sway bars for E60 aren't that THICK that you'd hate it for daily drive.
I think Eibach or AC Schnitzer makes a more "conservative" sway bar than H&R's
^^^^ IMHO, others may vary
My Ride: 2008 528i: Silver/Black/Light Wood, ZPP, ZCW, STEP, Comfort Seat, Heated Rear Seat, PDC, Xenon, Nav, iPod. 35% ceramic tint, VentureShield clear bra.
what's the performance package on the 550? I assume it's the standard sport package.
Anyway, on Tirerack the only set of shocks that I can find for the 2008 5 series are Koni FSD. I assume that the LCI didn't result in much change in suspension set up. Bilstein shocks are not even listed for 2008 models.
Originally Posted by Terraformer' post='759821' date='Jan 5 2009, 11:58 AM
I have an 04 530i 6-spd, no frills, 29K miles. That is, regular suspension (non-sport), no cold weather package. (But it does have luxury package--I think it's called--with leather, sound system, etc.) So far, the only mod is 19" Michelins on 166s (non-M6 offset to boot).
This past weekend I test drove an 07 550i with the performance package (I'm assuming that means all bells/whistles). It handled crazy good, very tight and responsive as you all know it is. While I'm not yet interested in upgrading (I'd take a bath on my 04 that I purchased), I am interested in trying to get some of that handling in the 550i.
My question is, what can I do to improve my 530's handling? I've read here about springs, coil-overs, and other things, but I am ignorant of what these things each, or collectively, give you. I'd like to improve my car's handling, but at what cost? What do springs give me? What do coil-overs give me? Can I get spacers that 'fill-out' the rear wheel well (which is what I assume the M6-offset would have done)? Are there other things to do (I'm sure sway bars and other things are options)? What do each of these cost? I am not interested in going nuts and spending thousands, maybe up to a thousand (preferably no more than several hundred). Is it worth doing? Or should I just sit tight with what I have? What manufacturers/part #s do you suggest if springs only? If coil-overs? Spacers?
Thanks for any and all input!
The way to kind of "test" it is to check 2008 Koni's part # against 2005.
And other known Spring part #. If they are the same then more than likely there's no changes in suspension design.
Tirerack is rather slow in updating their part #s.
aqualibrium
07-21-2015 03:11 AM
