Fuel line for in tank fuel filter replacing need help
Old 01-13-2016, 07:59 AM
BostonJon's Avatar
My Ride: BMW 530xiT (E61)
Originally Posted by DB_Gutz
Could it be possible to over tighten the collar?
I suppose that is possible, which may result in cracking the filter housing??
Old 01-13-2016, 08:26 AM
twh
twh's Avatar
My Ride: 2006 BMW 530xi 6MT
Engine: N52
I'm guessing if you got a gas cap message that something you did isn't seated correctly. Would be too strange to have the gas cap die at the same time.
Old 01-13-2016, 08:29 AM
DB_Gutz's Avatar
My Ride: 2006 530i cold weather package
Originally Posted by BostonJon
did you replace the o-ring when you replaced the filter? perhaps the new filter is not seated in the same orientation on the old gasket and there is a pressure leak?
Yeah I went ahead and took it all back apart and reset the assembly o-ring plastic collar and metal collar. I'll report back after a few test runs
Old 11-23-2019, 03:06 PM
treiberg's Avatar
My Ride: 2007 530i
Did you ever figure out the issue, mine is doing same thing.
Old 08-31-2023, 09:47 AM
Probation Members
Imjustagoodguy's Avatar
My Ride: 535i
Default Fuel filter line
My fuel line that comes off the in the tank fuel filter is leaking fuel from the quick connector so I've odered a new filter assembly and a new fuel line. I've found plenty of fuel filter DiY but I cannot for the life of me find even a diagram of where that fuel line even goes to from the filter. Does anyone out there have a diagram or a write up anything would help. Thanks in advance.
what was the part number for the fuel filter line and where did it lead 2
ripley
DIY: Do It Yourself
03-12-2024 01:01 PM
zoppp
DIY: Do It Yourself
06-04-2020 10:38 PM
shezm
01-03-2016 07:28 AM
Stranger12
12-26-2015 09:10 AM
PelicanParts.com
12-18-2015 12:55 PM
Quick Reply: Fuel line for in tank fuel filter replacing need help
