Fan, heat not working on all settings
Old Dec 15, 2008 | 02:02 PM
tbal's Avatar
My Ride: See sig :)
Doesnt matter if the car is cold or hot, the fan speed will not pass the 1/2 mark You think a bad battery can be a culprit? Wouldnt their be other issues if that was the case?
Old Dec 16, 2008 | 12:49 AM
tonymac's Avatar
I wish I would have finished high school and became the scientist I wanted to be.... Sorry man.
Tonymac
Old Dec 16, 2008 | 03:32 AM
Lancaster's Avatar
My Ride: 520d Black & SL350
Have you tried operating the heating with the aircon switched to off.
I have found that it's not possible to get truly hot air from the system unless one switches off the aircon.
If the system senses that the air is not hot enough, it will not increase fan speed. (Though I would have thought it would in manual mode).
Anyway, probably worth trying it with the aircon off...
HTH
Old Dec 16, 2008 | 04:15 AM
melimel's Avatar
Originally Posted by tbal' post='744670' date='Dec 13 2008, 07:01 PM
Nope settings DO NOT work past the 1/2 mark .. any suggestions? Bad blower motor thingy?
now you sound like me.. thats my word "thingy" lolol
Old Dec 16, 2008 | 05:00 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
I have the same problem and I have a bad battery. And I was also told that the blow heater is one of those things that the car prtially drops out when the voltage is low.
Old Dec 16, 2008 | 05:09 AM
porsche911targa's Avatar
You could have a bad resistor. I had a similar case where i changed the resistor on an E36 and the thing would work fine for a day or two and then it would blow the resistor again. Ultimately, it turned out to be a bad blower motor. G/L
Old Dec 16, 2008 | 08:58 AM
Ricracing's Avatar
Broken AC sensor, the resistor.
It is sooooo common on all E6x's.
I have read about more than 25 cases and I've had the same problem
in my '01 E39 and twice in my '05 E60.
On my '05 E60 both the resistor and the fan motor was changed, twice, as I said.
When the sensor brakes the AC goes on some kind of "preset level" on auto.
Therefore most people don't ever realize its broken, until one needs to do some
kind of special settings.
Old Dec 16, 2008 | 11:54 AM
tbal's Avatar
My Ride: See sig :)
So how hard is it to replace that sensor? Dealer vist?
Old Dec 16, 2008 | 12:12 PM
Anzafin's Avatar
The whole center console has to be removed and part of dash.
However, try the new battery at first.
If you're wondering did it help me, I have to say that I haven't done anything to this issue yet...
Old Dec 16, 2008 | 12:39 PM
Ricracing's Avatar
In the E39 it wasn't a problem (about 10 minutes) but in the E60/61 it is, don't know about the E63.
In the E60/61 it is a bitch (about 3 - 5 hours of work), because it's behind the dash...
But don't pay for the work nor the part, it is a such a common problem!
