Ever had your i-drive lock up?
Old Nov 3, 2010 | 08:40 AM
pjinca's Avatar
Originally Posted by or_550i
Interesting. The door and seat belt chime is sent via k_can to the ccc which creates the 'ding' through the speakers. If the ccc is locked up then the chime won't work. Either the k_can is shorted/grounded (which in my experience causes the instrument cluster to light up like a x-mas tree along with ever error message that can be produced) or your ccc has some major issues. Try removing the negative side of the battery for 15 min. This should cause everything to reset.
Yep, it might work. It didn't work for me, I tried it, and I tried a new battery, neither helped. CCC was still dead, deceased, no more, kaput
Old Nov 3, 2010 | 01:09 PM
or_550i's Avatar
I take back what I said then! After fooling with the k_can and doing several stupid things, while driving, I am amazed at how robust the CCC/mask/TCU/etc... are.
Old Nov 3, 2010 | 04:00 PM
mels545's Avatar
My Ride: 95 M3 CAI, chipped, pulleys, Xbrace, doesn't give headaches every time I start up! 04 545i all the goodies INCLUDING HEADACHES!
After the "reset" through the menu button I haven't had any problems with the i-drive and all functions work but it's been only one day. But another thing that i've noticed is that before when I get into the car and placed the key near the ignition the seat belt chime would activate (without even placing the key in the ignition or having the set belt on). Now I can put the key in and it will only chime when I turn the key!
I think there are some gremlins around or my battery may be going dead?
Old Nov 3, 2010 | 08:29 PM
pjinca's Avatar
If it's the original battery, then yes, it can easily be the battery. If after you replace the battery you still have issues? Then you will be on the same road I am on, sorry, and good luck
Old Nov 4, 2010 | 07:51 AM
mels545's Avatar
please excuse my ignorance but what do these acronyms stand for that mention above?
Old Nov 4, 2010 | 10:46 AM
Munich77's Avatar
I have had it lock up once - I drive was stuck in radio and did not turn off when the car was turned off. Thankfully it fixed itself.
Tymm
May 30, 2016 06:23 AM
Johnny B
E34/E28/E12 Discussion
Dec 25, 2015 05:33 AM
msaudino
Nov 1, 2015 03:52 PM
Tsubasaftl
Sep 12, 2015 01:34 AM
jhawk19
Sep 7, 2015 12:11 PM
