Hello, for background info the car has been driven without front driveshafts and without the fuses for transferbox. Now the front driveshafts and fuses back in the light trifecta wont go away. Below is all the error codes from the car if somebody can connect the dots. Also cant seem to do the vtg function check or servomotor and clutch test. Pic for that error code also.
there seems to be lot of battery related codes so could this all be caused by battery or alternator? Any ideas on what to do would be great!
Should i see the alternator load move? It stays at 0% This comes when trying to do any calibrations etc to transferbox
and to clarify the main thing here is getting the 4X4 abs ebv lights off.
ask for more details if you are confused by my explaining
