E60 Transmission oil flush?
#61
Originally Posted by pinguhk' post='1035406' date='Oct 18 2009, 10:37 PM
1st never trust the sale ppl.
I would change it now.
I change my oil at 45000 km, I change because the gear box started to jerk abit and not smooth even I reset the computer.
here is the oil you will need to get and the oil filter tray
Based on the photos, are you planning to use the ZF-Lifeguardfluid6 AT fluid? It should be compatible according to this document:
ZF_AT_Fluid_Information.pdf
#62
Originally Posted by MRV99' post='1036638' date='Oct 20 2009, 09:48 AM
If you want to replace the filter you will have to buy a new pan. the filter is built into the pan plus it is now made of plastic and once removed it will never seal properly. From the techs that I have spoken with, the pan is broken almost everytime they remove it. They also said that if you elect to change your fluid, they will make you purchase the new pan no matter what. If your a CCA member you get 10% of the pan
#63
My Ride: Mini Cooper
Attachment 92712
Attachment 92712
#64
Originally Posted by vwvwvw' post='1037214' date='Oct 21 2009, 12:54 PM
Who would design a transmission oil pan out of plastic? And one where you can't replace the filter? I'm thinking these are not the quality, durable cars I thought I was getting.
#66
Erm... this might be so obvious question. that manual tranny need replace the oil too?
I ask cause as i go through the site i couldnt find one for manual. they all auto tranny?
can any one confirm this?
Thanks
Thanks
#67
Just got done, took almost 3 hrs all together out of which over 1 hr was spent getting the car on 4 jack stands and down. Will write more details tomorrow.
Regards.
Raj
Regards.
Raj
#68
Regards.
Raj
Regards.
Raj
#69
Originally Posted by pinguhk' post='1037877' date='Oct 21 2009, 11:50 PM
congrats is it smoother?
Raj
#70
A few pictures..
Transmission has 75k on it. I guess it all depends, what kind of soup you want to run in your car? Eggdrop or HotnSour
More details with a DIY to follow.
Regards.
Raj
Regards.
Raj
