E60 Both power seats and steering adjustments not working
Hold on you have an OBD2 reader that can read the SRS and no codes are coming up. You need to send it back. I have a Launch and it reads everything that can log errors. If you want a code reader get the X431 pro elite. It will save you money in the long run or you can get INPA via BMW tools with a K + Dcan cable. You can't troubleshoot a foreign car with a basic code reader. They are too complex.
Engine: 3.0 B58; 3.0 M54
I've never seen the BST itself throw the SRS light. It's always been paired with an error for a device apart of the SRS system (seat belt, occupancy mat, etc.), with us knowing it is the BST causing the issue.
BST throws an airbag notification in the i-Drive along with the SRS icon. I got thrown off initially because I had no airbag codes but I did have BST code in SGM. I cleared that, and the airbag notification and SRS icon extinguished. That's because BST works in conjunction with the airbag circuitry.
Mine throws the SGM fault 100-percent of the time.
But thanks to you, I have no more intermittent airbag notification. That was driving me crazy, and I did not want to do the BST bypass trick.
Yeah you were thinking the same thing I always thought. I was not going to do the bypass. I did manage to get a cable out the junk yard and soldered a resistor to it but never installed it. I have it just in case. I made it so it plugs into the existing plug. I wonder why no one ever does that.
mboat
Mar 24, 2018 09:28 AM
topajo
Jan 21, 2012 02:01 PM
