DVD Nav does not recognize the DVD
Old 09-07-2012, 03:10 PM
Phil75070's Avatar
My Ride: See signature
Originally Posted by Rez
Just bought the 2012 OEM set BMW p/n: 65 90 2 241 717 from:
http://www.ebay.com/itm/251142813099...=p5197.c0.m619
Got scared of the burnt ones messing up the DVD drive.
Did you look at the seller's feedback? A couple of people say his discs are burnt copies, too!
Old 09-08-2012, 08:29 AM
Rez
Rez's Avatar
My Ride: 2021 BMW 540i XDrive Bluestone Metallic on Ivory White Napa Leather. Packages: Executive, M Sport, Parking Assistance, Luxury Seating, Shadowline. Options: M Sport Brakes with Blue Calipers, Body Color Rocker Panel Blades and Spoiler, Heated Steering
Model Year: 2021
I saw a 100% positive feedback on the seller, who claims these are OEM. The seller has a 14 day return policy. If they don't happen to be OEM, I will send them back for a refund.
The apparent burnt ones were much cheaper. Hopefully, the seller has integrity.
Old 09-08-2012, 11:33 AM
Phil75070's Avatar
I can't imagine a "burned disc" causing problems with the drive itself. Few if any of us have the capability to "replicate" (as opposed to "duplicate") DVDs and would they even sell blank DVDs to be burned if they caused damage to a DVD drive?
Old 09-10-2012, 05:20 AM
best1's Avatar
My Ride: 2008 550i M-Sport
How would a burned disc damage a dvd player? In the same regard would a burned CD damage the cd player? This does not make sense to me????
Old 09-10-2012, 05:25 AM
luigi524td's Avatar
It's gotta be an old wife's tale - I've been using a home-burned copy of my factory original DVD map for more than 5 years w/o any - repeat no - problems. . Did the same on past two BMWs after my very first BMW supplied Nav "CD" mysteriously disappeared after a service visit! (YES, early BMW NAVs used a CD map!)
Old 09-10-2012, 12:19 PM
Phil75070's Avatar
It is possible to damage a drive by doing extensive burning of discs. I think that is because higher intensity of the laser is used to actually burn a disc as opposed to just playing a disc so heat can build up if burning one disc after another.
Old 09-10-2012, 12:47 PM
Jim165's Avatar
Originally Posted by advancedlogic
I'm using discs from this seller:
Ebay $50 E60 CCC 2012 Navigation DVD Set
Keep in mind these are burned discs. There has been periodic discussions on possible negative effects on the DVD drive lifespan using burned discs, but nothing conclusive. They work fine on my retrofitted CCC system.
Are these discs single layer or dual layer?
I ordered a 2009.1 disc for my car when i purchased it, and it constantly struggles to read the data and after awhile, it'll just quit. I know that the 2009.1 discs were dual layer and the data was corrupted in one way or another, plus our cars had trouble reading dual layer discs. I suppose my drive is going bad as well..
best1's Avatar
That does not make sense!!
Old 01-08-2019, 03:31 PM
carlo525's Avatar
My Ride: 6 speed
Default I have exactly the same problem
My old DVD works (2007) but the new one I bought (2015) does not work.
We know that the problem is not the reader because the old DVD works.
The new DVDs are probably not bad, they just aren't formatted in the way that the reader expects.
BMW screwed up.
They didn't regression test for backward compatability.
The dealer said they are looking for a part # for a DVD that was formatted correctly for the 2009 525 DVD reader.
In other words, the latest/greatest DVD is no good for a 2009 reader. We need an older version of the DVD
Yellow Dog
11-25-2019 06:27 PM
jcolley
08-01-2016 06:48 AM
msaudino
11-01-2015 03:52 PM
Claudiupromotion
09-17-2015 08:02 PM
Bank$hot530
09-16-2015 01:28 PM
Quick Reply: DVD Nav does not recognize the DVD
