5Series.net - Forums
-   -   DVD Nav does not recognize the DVD (https://5series.net/forums/e60-discussion-2/dvd-nav-does-not-recognize-dvd-125693/)
team23jordan 08-17-2012 09:54 AM
I have 2009 528 XI and Navigation completely stopped working..
It worked on and off for awhile..even when the disc is in, it says to insert a disc..
What do you guys think the problem is?
The disc itself is very clean and scratch free
Turbotuners 08-17-2012 10:20 AM
try resetting the Idrive system.. hold down both eject bottons (1 for the cd, 1 for the dvd) and push in the mute volume knob hold down for anywhere from 10-60 sec hold in all 3 till it turns off and turns back on. hope it helps
Rallyman1984 08-17-2012 10:34 AM
If it doesnt, it's probably the drive itself thats decided enough is enough....but dont panic, I've just had mine refurbished and a new laser for close on 150, there is a few ebay people doing it.
I got mine done by Car Audio Technics in Essex (I have no association with them) but they done a good job of mine.
team23jordan 08-17-2012 12:22 PM
Can you provide a link to the auction you won?
I just wanna see the pics, part # and etc
luigi524td 08-17-2012 04:02 PM
A DVD can "look" clean and scratch free but may have a bad sector that prevents it being read by the NAV drive. See if your drive will read a music CD - to rule out the NAV drive. Unless you are high on miles your car should be under original warranty - if it is, let a dealer sort it out now (even the originally supplied DVD!!).
team23jordan 08-21-2012 03:18 PM
Just came back from a business trip.
Anyways, DVD player reads regular cd perfectly fine.
I think NAV disc has a bad sector as you described.
Does anyone know where I can buy a new nav disc for cheap?
advancedlogic 08-23-2012 11:42 AM
I'm using discs from this seller:
Ebay $50 E60 CCC 2012 Navigation DVD Set
Keep in mind these are burned discs. There has been periodic discussions on possible negative effects on the DVD drive lifespan using burned discs, but nothing conclusive. They work fine on my retrofitted CCC system.
team23jordan 08-27-2012 12:57 PM
Just ordered the west disc. Let's see how well it works
Thanks for your help! https://5series.net/forums/public/st...ault/twoup.gif
AchtungE60 08-29-2012 01:20 PM
Let me know if that West disc doesn't work. I think I still have my West disc put up somewhere.
Rez 09-07-2012 01:35 PM
Just bought the 2012 OEM set BMW p/n: 65 90 2 241 717 from:
http://www.ebay.com/itm/251142813099?_trksid=p5197.c0.m619
Got scared of the burnt ones messing up the DVD drive. :nono:
© 2019 MH Sub I, LLC dba Internet Brands
