Driver Airbag Buzzing noise
My Ride: 2006 BMW 550i CPO bought in Jan 2009
Did a search and found a lot of topics on noises in our cars, but none specific to the driver airbag in the steering wheel. It buzzes when I go over rougher surfaces and if I press down lightly towards the floor (not like pressing the horn), the buzz goes away. Anyone else have this issue? any fixes?
I also have a buzz from the driver side a pillar, sounds like its coming from the tweeter area. The strut braces were checked/tightened, but that did not fix it. I'm thinking I'll need to take the door panel off and snoop around.
I had that issue but the dealer fixed it about a year ago. I placed my hand on those switches and the buzzing still happens, place my had on the air bag/horn and it stops
My Ride: Bmw 530d 2004
You may want to dismount the airbag and see if there is an obvious reason visible for buzzing.
Dismounting the airbag is quite easy:
1) Disconnect the battery negative pole
2) Let the system drain for 10-15 mins
3) Put a screwdriver in hole under the steering wheel and push a metal wire to unclip the airbag
4) Help with your other hand and take the airbag unit off
5) Disconnect wire connections if needed
6) Check for rattling items
Putting everything back is doing everything vice versa.
- Antti -
- Antti -
srogers535x
08-05-2015 08:48 AM
