differentiating differential noise from wheel bearing
Old Sep 4, 2015 | 01:24 PM
snoop's Avatar
My Ride: 2004 530i
Default differentiating differential noise from wheel bearing
My car has about 170k on it and it has rear end noise, the conditions are as follows
  • Independent of engine RPM
  • Noise occurs above 20 mph
  • Noise occurs when driving straight, gets louder turning right and dissappears turning left
Is it at all possible for this to be coming from the differential? My thoughts were that this part was not effected by lateral Gs.
Old Sep 4, 2015 | 05:00 PM
KyleB's Avatar
My Ride: 530i
Engine: M54
This is precisely how you test for a bad wheel bearing. In your case, since the noise goes away during left turns when you are loading the RIGHT side of the car, you should suspect the bearing on the left side.
Old Sep 9, 2015 | 08:47 AM
pcy's Avatar
pcy
One way to test front wheel bearing is as following -
Grab the front tire on the top and rock back and forth (towards you and away from you) really hard. First it will feel like there is no movement... after rocking several cycles, you will hear the noise.
Repeat the same process for the other front tire.
MrTE61
May 3, 2015 08:10 AM
shoryuken15
Apr 9, 2015 03:42 PM
LAMike240
F10 Discussion
Mar 17, 2015 08:24 PM
gonzo40
Jan 7, 2004 01:38 AM
