Day Time Running Lights
Old May 10, 2006 | 05:57 AM
alberto's Avatar
My Ride: 535d touring eletta 2006: 272 HP (560 Nm), A08 Silver Gray, LCSW black leather (dakota), 522 bi-xenon headlights, 402 panoramic sun roof, 508 PDC, 589 17" styling 122, 609 navi prof & dvd, 205 steptronic (standard), 488 lumbar support, 502 headlight cleaning system
hi everybody,
i just went thru some old posts here in the forum about Day Time Running Lights.
Actually I do have a similar option in my E61 (i'm posting here as i believe this option
is pretty much the same on both e60 and e61).
I was just curious to ask : with the Day Time Running Lights on, with a bi-xenon
headlight system, which lamp you have on ? The xenon or the inner one (that used
for flashing a slower car in front of you )
as always, thank you very much for your opinion !
Old May 10, 2006 | 06:02 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
DRL uses the inner, non-xenon lamps, I believe...
Old May 10, 2006 | 06:06 AM
alberto's Avatar
Hi Rudy,
thank you very much for your reply, do you think I can have this set by the
dealer ?
My Day Time Running Lights option uses the xenon, which is a non sense,
IMHO the Day Time Running Lights option should also extend the xenon bulb
life.
thx in advance, Alberto
Old May 10, 2006 | 06:16 AM
EBMCS03's Avatar
life.
Really? I dont think thats correct. DRLs are suppose to use non xenons (inner flash to pass halogen) bulbs
Old May 10, 2006 | 06:38 AM
alberto's Avatar
Nor do I, that's why I'm asking the forum ... car is due in for service next monday,
and you know, better be prepared ..... just fonud today a technical service
that says my dvd needs to be replaced while they were claiming "recoding" was
enough
Old May 10, 2006 | 07:55 AM
Ricracing's Avatar
In the Nordic counties the daylights are obligarory.
It's the normal Xenons that burns, in half-beam.
I actually have the light switch "on" all the time!
Old May 10, 2006 | 10:07 AM
jmdhuse's Avatar
My Ride: 2006 530i - Sport - 6spd - Orient Blue with Auburn/Anthracite
I have mine set with DRL on (US spec car) and the Xenons are on all the time... I believe this is noted in the manual, although it's pretty subtle...
Old May 10, 2006 | 11:59 AM
2DOR's Avatar
My Ride: 2005 545i, 6 speed, black sapphire with beige leather, style 128 wheels, and clear bra.
My DRLs are not the Xenons but the inner non xenons. Picked up from dealer that way.
Old May 10, 2006 | 03:51 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
I need a scorecard to keep track of all the differences in DRL settings between countries!
One thing to keep in mind for those that are trying to gather data -- you should verify the DRL's with the headlight switch in the off (12 o'clock) position since the automatic setting often results in the headlights being on...
Old May 10, 2006 | 11:30 PM
tonye60's Avatar
there is an option in idrive for drl on a uk bmw
