Cupholder theory
My Ride: [i][b][u]Since 19 august 2004[/u][/b][/i]: [color=red][b]530i[/b] High Executive[/color], Silvergray with beige interior, Popular wood, Servotronic, Sportssuspension, electric foldable and dimmed mirrors, dimmed interior mirror, pappelmaser braun wood, cupholders, styling 123 18" wheels, Logic 7, Steptronic, alarm class 3, electric sunscreen in the rear and suncreens for sidewindows, Comfort seats, heated seats, Xenon with headlightwashers, Adaptive corner lights ALC, Advanced airconditioning, lightpackage, Nav Pro, 6 cd changer, side airbags rearseats, bluetooth siemens S55, chrome kidneys, gearlever with wood, voice recognition retrofit, front windshield with green band.
Waiting for trunkopener button from Hobi :)
Originally Posted by Memotronic' date='Apr 2 2005, 10:43 AM
believe it or not :thumbsdown:? it won't hold any thing?
Attachment 6379
Attachment 6379
[snapback]110263[/snapback]
Originally Posted by Guest' date='Apr 2 2005, 06:37 PM
My dads car is of september 2003 and have the cupholders like on the pic in the first post.
We don't have problems it can hold easy a cup to 50 cl.
[snapback]110284[/snapback]
Originally Posted by wolverine' date='Apr 1 2005, 12:35 PM
Both 'versions' of the cupholders have outer and inner rings.? Here is a copy of a post I just made on another thread:
I have modified my cupholder and it works beautifully for large and small soft-drinks, 16 oz cokes, Starbucks, red bull, and plastic tumblers. It's not a simple modification, but I'll try and explain it for the brave few that want to try it. There are two phillips-head screws that hold the cupholder into the dash - you can remove the entire assembly very easily.
There are two problems with the BMW cupholders. First the spring-force on the outer ring is too much. There are two springs used, a strong one for the outer ring, and a weaker one for the inner ring. You remove the outer ring spring so that only the spring used for the inner ring operates both outer and inner rings. By removing the spring attached to the outer ring, both small and large rings then use just the one spring, and the spring force is reduced.
Second, if you look at the bottom support arm, it does not deploy so that the upper part of the arm is vertical, it is at an angle. A drink that is not heavy enough to move the outer ring will sit on the angled part of this arm, or will be pushed up the arm and 'spring out' of the cupholder.
To modify the vertical arm, you have to use a dremel tool or file. There is a stop in the mechanism that controls how far the arm moves when it deploys. If you take some material off the stop, the arm will deploy farther. Take enough material off so the arm deploys to the vertical position.
Well, like I said, it's not simple but these two modifications make the cupholder perfect for any container I've tried. I don't know why the Germans didn't do this in the first place. If you screw the modification up, just have the dealer replace it. They're used to it!
[snapback]109912[/snapback]
My Ride: Nothing to boast about!
Originally Posted by boling8080' date='Apr 2 2005, 08:58 PM
Great work wolverine.? Thanks for the research.? I was thinking about taking out that outer ring spring.? Now I know I have to do that as well as the dremel work.
[snapback]110399[/snapback]
My Ride: 07' 530d - M-Sport - Titanium Silver / Black Dakota leather
08' 120i - M-Sport - Alpine White III / Black Sensatec
Originally Posted by paulwbenn' date='Apr 3 2005, 12:09 AM
Those who complain about the E60 cupholders must never have used the ones in the E39.? What a joke.
[snapback]110380[/snapback]
Vman33
03-14-2022 04:43 AM
