Creaking and Crackling
Old 10-11-2011, 02:51 PM
  #21
syrousd's Avatar
My Ride: 2008 550I,Space Grey,Hud,Cold Weather,M - Sport, matched GP Thunder headlights and Fogs,,Smoked Badges, Night Vision, Heated Seats,Rear Sunshades, Aux Audio, SAT, NAV, Black Grills, Sprint Booster, Dinan Cold Air, Stage 2 Dinan Software.....More to come soon
Originally Posted by vkhong
I use 3M Silicone Paste for weatherstrip (rubber only) on all my vehicles, spark plug / electric connector boots, and the electrical connectors on my trailer hitch and trailer. It comes in a thick paste.
(Select for product info)
Yes the 3M Silicon woks well, all depends what you want,how much you want to spend,convenience so on......
Old 10-11-2011, 11:37 PM
  #22
Terras14's Avatar
Originally Posted by syrousd
NO!!!!! Just the two rubber pieces one on the door and one on the body!
Thats great, thanks..i try it out.
Old 10-17-2011, 01:32 PM
  #23
King's Avatar
My Ride: BMW 530DA 07/2006 - Carbon Black - M-sport - Logic7 - Navi Professional - Xenon - Telefon/bluetooth - ACM-module
Try Wurth Rubber Care and your problem is gone. Bavaria (BMW) use this in Norway:-)
I use this product one time pr. year and the noise is gone.
Old 10-17-2011, 05:24 PM
  #24
p3style's Avatar
My Ride: 2004 545
Gel or aerosol form?
Thanks for the tip!
Old 10-20-2011, 12:48 PM
  #25
King's Avatar
Thanks for the tip!
I am using aerosol form.
Old 11-20-2011, 04:18 PM
  #26
REALIST-E60's Avatar
My Ride: 2006 BMW 530I
Originally Posted by Theo
Before you go the (proven) route of silicone, carboflo, gummipflege, BMW teflon tape or even new seals there is an easy fix you should try:
If you clean all the felt parts of your seals somewhat throughly, for example with a high powered carwash vacuum cleaner and if necessary a new toothbrush to get in the upper slits for the glass windows the noise just might be gone.
Will cost you 10 minutes max and chances are you'll be noise free for quite a while. If not, address the rubber seals...
My dealer applied the 3m tape all aound my car's door seals and the noise came back after one rain fall :S i dont know what to do...
Old 11-20-2011, 04:34 PM
  #27
sy1616's Avatar
Ask dealer to tape, in or out of warranty.
Old 11-21-2011, 03:42 PM
  #28
p3style's Avatar
My Ride: 2004 545
Awesome thanks! How did you apply? SPray right onto rubber?
I was afraid it might spray everywhere so applied the product to a cloth first then applied to the seals.
Old 11-22-2011, 01:05 PM
  #29
bao550's Avatar
i had the same problem you guys have. What I found out is that the wind deflector of the sunroof. So I put some velvet tape between the notches of it.
Old 11-25-2011, 01:45 PM
  #30
King's Avatar
I take a cardboard and cut out a thin stripe and spray through. I also use a small cup and a paintbrush or applied the product to a cloth first then applied to the seals.
Quick Reply: Creaking and Crackling
