Creaking and Crackling
Old 09-23-2011, 04:41 AM
shumaki's Avatar
My Ride: 2008 550i M-Tech Sport Package, Carbon Black, Black/Anthracite Bamboo
Past few days my interior sounds like a crackling fire over bumps on cooler mornings. Pretty sure it's the door seals. Any recommendations for door seal lube..... besides KY?
Old 09-23-2011, 04:55 AM
bmwfive's Avatar
Silicone spray?
Old 09-23-2011, 08:50 AM
toyota2bmw's Avatar
Believe it or not, Vaseline does wonders on the door seals to get rid of creaks and cracks.
I've gone about 6 months or so without any creaks since I last applied.
Old 09-23-2011, 12:53 PM
syrousd's Avatar
My Ride: 2008 550I,Space Grey,Hud,Cold Weather,M - Sport, matched GP Thunder headlights and Fogs,,Smoked Badges, Night Vision, Heated Seats,Rear Sunshades, Aux Audio, SAT, NAV, Black Grills, Sprint Booster, Dinan Cold Air, Stage 2 Dinan Software.....More to come soon
OK...number one do you have warranty if you do BMW has an ECO that applies and invisible tape on the interior of your doors, they did it to mine and it is fine. Number two...if you don't have warranty use Petroleum Jelly and rub it on the both seals (body and door) and it will solve this issue!
Good Luck!!!
Old 09-24-2011, 12:45 AM
Theo's Avatar
My Ride: 2004 E61 530D - Dynamic Drive - Active Front Steering Sport Seats - Voice Control - Head Up Display - Nav Pro - Bluetooth - Panoramic roof - Front/rear heated seats
Before you go the (proven) route of silicone, carboflo, gummipflege, BMW teflon tape or even new seals there is an easy fix you should try:
If you clean all the felt parts of your seals somewhat throughly, for example with a high powered carwash vacuum cleaner and if necessary a new toothbrush to get in the upper slits for the glass windows the noise just might be gone.
Will cost you 10 minutes max and chances are you'll be noise free for quite a while. If not, address the rubber seals...
Old 09-25-2011, 03:50 AM
shumaki's Avatar
Thanks guys. Got a chance to detail the interior and applied some silicon spray to the seals along with cleaning the rubber and felt parts. If it doesn't solve the problem, vaseline and then trip to dealer.
Old 09-26-2011, 04:41 PM
REALIST-E60's Avatar
My Ride: 2006 BMW 530I
I have the same problem.. i have the car for 4 months now and i brought it in at dealership.. they told me is was the door seals and lubed it with some kind of product(not sure what)..but the noise came back after two weeks. Is there a way for the noise to be gone permanently? picture of where and how to apply the product would be much appreciated.
Old 09-26-2011, 05:00 PM
p3style's Avatar
My Ride: 2004 545
Alright - so maybe i am in the minority - but mine only creak during hot days?!
Quiet as can be on cold days!
Just my car?
Anyway - 3m adhesive removal does the trick every time none the less.
Old 09-26-2011, 05:01 PM
p3style's Avatar
My Ride: 2004 545
Even after car washes?
I have to apply the 3m adhesive removal after every car wash to keep my interior quiet.
Let me know buddy!
Thanks!
Old 09-26-2011, 05:02 PM
p3style's Avatar
My Ride: 2004 545
I haven't found a permanent cure - but would be interested as well!
Quick Reply: Creaking and Crackling
