Coolant Temperature via OBD menu on 520d LCI?
Old Oct 20, 2011 | 10:27 PM
Maher's Avatar
Hi, Sorry to put this on here, i'm sure its covered here before but I can't seem to find the right info. I am trying to access the hidden menu to check my Coolant Temperature on my 520d LCI.
I'v tried following the steps found on youtube on this
but when I tried that on my car it goes to normal Time & Outside temp display at the last stage at 07.00 (KTMP-MOM)? I tried the same procedure in my friends car who has 520d Pre-LCI and it works fine??
Is their a different procedure for LCI models? Please advice.
Old Oct 20, 2011 | 10:42 PM
Anzafin's Avatar
My Ride: Bmw 530d 2004
Are you sure you calculated the sum of the 5 last VIN numbers right?
Try this to check if the hidden menu is opened or not:
- Go to folder 19 and put the sum there
- Then go back to folder 19 and see if the menu is still locked
- If it's still locked, you put the wrong number in
- Antti -
Old Oct 21, 2011 | 12:20 AM
Maher's Avatar
Thanks Anzafin, sorted! I was adding last 5 digits!! Thanks for your help. Now I can check my coolant temp and see if it is right or wrong?! I'm I right to say that it should around 92'C?
Old Oct 21, 2011 | 12:43 AM
Maher's Avatar
Amendment is last comment! I was using last "6" digits and not last "5"! :-))
Chet
152
Jul 8, 2018 02:26 PM
UltimatePeter
DIY: Do It Yourself
May 12, 2015 08:00 AM
Stranger12
Apr 5, 2015 10:42 AM
linxuan
E39 Discussion
Mar 22, 2015 06:16 AM
fmusbmw
Bluetooth & Cell Phone Forum
May 14, 2004 11:41 PM
