CLUTCH SLIPPING
I HAVE A 2005 530I SPORT 6 SPEED MANUAL TRANS.
BETWEEN 4000 - 5000 RPM IN EITHER 2ND OR 3RD GEAR I FEEL WHAT SEEMS TO BE THE CLUTCH SLIPPING.
AFTER 5000 RPM, SLIPPAGE STOPS AND CAR ACCELERATES NORMAL.???????????????
ANY IDEAS
ANY IDEAS
My Ride: G30 M550i
Model Year: 2018
What happens if you floor the accelerator in say 4th or 5th gear while at around 2,000 or 3,000 rpms? Does it slip a bit?
From your description, it sounds like a slipping clutch. In my experiences, a worn clutch can slip under various conditions -- sometimes worse than other times...
My Ride: 2006 530i Sport
Silver Gray - Black Leather - Anthracite Maple
Manual Transmission
Premium Audio
Cold Weather Package
Rear sunshade
Sirius Radio
Autobahnd Roadblock (3M) film kit
Also, I'm thinking this could possibly be a case of the earlier manual 3.0L cars having that "hitch" in acceleration around that RPM. It has been a while since the forum had any traffic on this issue, so the OP might have to dig a bit, but this was a known peculiarity that some people had service work done to correct.
ANY IDEAS
ANY IDEAS
My Ride: 2005 525i M Sport Automatic Gearbox Front Seat Heating Leather interior Media Package
Originally Posted by Russ1974' post='458943' date='Aug 15 2007, 01:48 PM
I have heard of this before. What has happened is that your Caps Lock key from your computer keyboard has fallen off and got stuck in the transmission.
Not for the guy thats got the slipping clutch, but thats funny Russ!
My Ride: 2004 545i - 6 speed manual (July 04 build), silver-grey/black, sports package std equipment (18", active roll, active steering, adaptive headlights), premium sound, bluetooth enabled, folding rear seat, lumbar, 3m hood/bumper protective film, rear tint, euro reflectors.
ANY IDEAS
ANY IDEAS
I was having a problem with my map sensor that was causing irregular engine operation, which at first I thought I was having a clutch problem as my shifts where screwed up.
My Ride: Numero Uno in Richmond Va 04 530 6 speed, jet black, black dakota leather, xenons, red rear reflectors, 545 front grill, cold weather package, premium package, staggered 19 inch BBS rxII/michelins, H&R coilovers and intergrated, R1 concept drilled an
Engine: 530i
how many miles? I have 42000 on mine driven hard, but not abused and I have not problems other than the slip when the traction control kicks in and the annoying clutch delay valve are you sure its not the traction control?
PelicanParts.com
Sep 10, 2015 10:02 AM
PelicanParts.com
Aug 13, 2015 01:45 PM
