Check Engine Diagnosis Help
Your safety gateway module is another story and is unrelated to this issue. If you have INPA set your default printer to XPS document and then do a print in INPA and save it. It will tell you how long you've had it and the frequency and the error.
As far as a fuel system cleaner, the Lucas is fine. Just put 6 oz in. and fill tank to premium
