Changed Battery, some issues.
The battery's voltage is dipping down enough to cause the car to shut off nonessential electronic devices.
Since you changed the battery recently it was either replaced with a battery with too few CA and CCA values. The e60s like 1000+ CA batteries.
Also, technically you are supposed to have the new battery 'coded' at the dealer so that the electronics are reset to provide proper amount of charging amps to the battery - Never read a 100% positive message about this though. I changed my battery in the last month (because of the date/time loss) and NEVER took it to the dealer and I do not have any problems.
I would check the CA and CCA values of the battery, check the voltage on the battery when the car is running/idle [charging] (~14.4V), and check the voltage when the car is off (12.65V).
My Ride: '04 545i, sport pkg, premium sound, sprint booster,
Obviously they can be purchased at the dealership, but at a premium price.
Here's one place thats a good option: http://www.autohausaz.com/index.html
Ok so this whole issue regarding a dying or retarded/geriatric battery might be the thorn in my side as well. I Have noticed now in the last couple of weeks that when I listen to the radio with ignition/engine switched off that I get the "low battery" warning after a few minutes. In the last 3 or so days my interior fan - A/C blower will not go to full speed, it only increases fan speed on the 1st 4-5 turns from there on no increase to full speed - the A/C still cools down so no problem with gas. Might this be part of the "non essentials" that the car shuts down? I have checked fuse and reseated it. Battery bubble color also looks black as far as I could make out.
spitfire23
05-12-2015 04:23 AM
