cd changer problem..
I would take it to my dealer if the eject button does not work. You could see if there is a "pin hole" for ejecting, but I don't recall seeing one on my player hardware.
My Ride: G30 M550i
Model Year: 2018
I doubt that a pinhole manual release will help with a stuck magazine style changer. It's likely that whatever's jammed isn't going to magically unjam itself with any sort of manual, mechanical release.
The dealer (or you) should be able to remove the changer and carefully disassemble it to free things up...
My Ride: 2005 530i Individual, DVD Package, HUD, Bluetooth, Comfort Seats, SR, etc
there is a spring which releases the changer from locked mode, its run by a small motor, sometimes the the lock gets jammed for dirt etc. Just ask the dealer to service its and it will be working fine. It happened to my LX470 changer once. Its nothing dont worry~
It's very easy to remove the changer and open it.
You'll see 2 small plastic caps on the CD changer front, low left & low right. Open them and release the torx screws, this enables you to pull out the entire changer.
Disconnect the MOST/power cable from the back. Take the changer home and open (if I remember correctly, 5 or 6 torx screws and 2 cross ones).
The mechanics are easily accessible. If it's caused by dirt you'll be able to clean it easily. If it's a DC motor gone wrong you'll at least be able to manually remove the cartridge.
Good luck...
Tim
Good luck...
Tim
AirlinePilot
13
05-20-2024 05:56 AM
Vman33
03-14-2022 04:43 AM
Wonky
04-12-2016 08:15 PM
