CCC unit replaced
My Ride: 06 530i
I finally had my CCC unit replaced and when I got my car back, the sound quality became real horrible. I cannot turn on any music with bass as it will make my speakers vibrate. I know before my CCC went out, the sound quality was better then it is now and I'm 100% sure i did not blow out my speakers before my CCC unit died. Could it be a programming issue? Because one thing I noticed different is when I pop in a CD and i scroll to the CD select section (where it says DVD, CD, CD 1, CD 2.., etc.) is that I have that option. I used to only have the options for DVD / CD. But now those come out with CD1, CD2, CD3, CD4, CD5, CD6. I don't have premium sound or a CD changer so I was just assuming (or at least hoping) its just a programming error. Has anyone encountered this problem before?
My Ride: ///M5 BEAST
Sounds like a programming issue. Also check your sound settings. Do you have logic7 with all the adjustable eq settings 50hz thru 100hz etc? Also make sure that your sound / speed matching isn't set too high....it distorts the sound a lot by digitally compensating and raising the volume....
Haha, if chase is taking over, your in good hands I was going to suggest you contact him as your in the same town but felt it wasn't my place to offer his services.
DavaiLave
08-02-2022 02:16 AM
